Stepsides Are Bedder
Looking For No-Cut Radio Ideas
Our truck is pretty much unmolested so far, and we'd like to keep it that way, at least as much as possible...I'm looking for ideas or pictures of no-cut (sheet metal, that is...kick and door panels are fair game) radio and speaker installations, although I'm not ruling out the possibility of enlarging the dashboard cutout altogether...I'd just prefer not doing it.
Is there a clean way to do this? |
Cowboy Fan for Life!!!!!!
There have been numerous threads on this. Go to search and try "cut dash" or something like that. Do you have a bench seat or buckets? This makes a difference. With buckets you can always hide it in the console........later & welcome to the board from Va.................Jerry
1967 ShortBed Fleetside 3/4 Drop 350/700R4 Tilt wheel 18 x 8 Torque Thrust II's Future mods: All new gauges & wood bed My Zip is 23002 I ship UPS, USPS |
No-Cut Radidio Idears...
Thanks, Jerry! Shoulda done my homework first, but my daughter brought it up (I'm more concerned with the engine/tranny swap).
Are there any pics of your truck online? --Ed |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
We cary several sterios that are desighned to fit our trucks withour cutting the dash. You can find them in our "Sterios & Related" section of our website. Here is a link: http://www.classicheartbeat.com/stereos.htm
Here is a couple of pictures of the sterios: ![]() ![]() Let me know if I can help you. WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
Wes: Does Classicheartbeat.com have catalogs you can send out?
Truck69 ![]() |
Member since 2000
Here's a proven idea I've seen. You take an aftermarket radio with the detachable face on it. Instead of cutting your dash you make a pod for the face plate to sit in, you make a wiring harness so the pins on the back of the face plate can connect to the main head unit pins. It's been done and you can mount the player anyhere you want. With the face plate sitting in it's pod you can attach it to the uncut part of the dash where you can easly created a mounting bracket. it's not hard but would take some time.
If you want the detahcbale face option then just take of the whole front section of the radio where the face mounts off the radio, gets some ABS plastic and make a template so you can cover up the extra place on the head unit, but make sure to cut a slot for the CD. |
FUEL CELL GURU
If you use...
and aftermarket a/c and heat combo, you can do what I did. Oh, the knobs on either side of the hvac controls is the headlight and wiper switch. I got those out and away from the already clustered gauge cluster.
http://customautosound.com/
Custom Autosound (what wes is showing) makes the decks and kickpanels that prevent cutting. I have used numerous head units from them and they work good. Here is one in a 67 Suburban I did recently |
67-72 Addict!
Heres mine like the one above
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
67-72 Addict!
My CD player mounted in glovebox
Mounted on the front of the bench seat with custom "Z" brackets. I was going to go with the glove box, but what a pain to change a station. This has worked out good and I sill have the stock radio in the dash.
Just sitting here contemplating contemplation. |
I used a CB radio bracket to mount mine under the dash. Used the two screws under there, so no drilling. I have never had any problems with skipping or getting dirt inside the radio. It has been like that for over four years now.
72 Cheyenne 1/2T LWB original ochre/white 09 Silverado ECSB 76 International ScoutII |
#13 |
Merciless Butcher
Overhead Option
Here is another option. It's made by Roddoors. It's sent to you larger than it needs to be because you cut it down and shape it to fit the contours of the ceiling in your truck. It comes complete with all of the necessary mounting hardware. The front of the console can be cutout to accomodate a DIN (square) faced radio. The idea is to shape it to your taste, then it can be covered with fabric or painted to match the interior. I think there is a picture of a completed console at www.roddoors.com After I finish shaping it, my upholsterer said he can cover it with 1/8" closed cell foam and cover it with leather to match the rest of the interior. I ended up cutting the dash to install a CD player. This will work well for extra storage after I cut the front panel out.
This should be a direct link to the page with the console. There are some other radio mounting alternatives on this page too. The overhead console looks awesome finished. These are made of ABS plastic so they can easily be glued with ABS glue from the hardware store.http://www.roddoors.com/mapconetc.html
Your Bought And Sold....I Got Your Soul! Last edited by gonebad2; 02-11-2004 at 10:40 PM. |
#14 |
![]() Join Date: Apr 2002
Front speakers up under dash out of sight, rear boxes and amp under seat, radio in homemade console, which can be closed so only AM radio/ speaker is visible- used when parking in the ghetto.
'69 Chev Cust/10 swb, 350/700R4, 5"/6" '70 Chev C10 swb, 67 front, 454/700r4, 4"/5" '73 Chev stepper, 350/3 spd '84 Chev K20 350/4 spd '91 GMC 1500 Suburban 4x4, 350/700R4 |
#15 |
closed
#16 |
gonebad2, thanks for the link, show us what it looks like when finished! billogna, that's also a great idea, looks nice and discreet when closed too. What material did you make the console out of?
1972 Chevrolet Suburban ('68 front clip), 2wd, 350/350, factory tilt 2008 Kawasaki Concours 14 ![]() 1997 Harley-Davidson Soft Tail Custom 1948 Chevrolet Coupe (project) 1972 Porsche 914 |
#17 |
Merciless Butcher
Billogna, I like your floor console. It has a nice clean look. More info on how you made it would be great....Stay out of the ghettos, I would hate to see some scumbags get ahold of your nice ride.
Your Bought And Sold....I Got Your Soul! |
#18 |
Billogna...
Please, more details on the console!
What I would like to do is install one of the stock-looking AM/FM radios, but I would like to have one that has a CD-In jack (I have a radio that has this feature in our motorhome), or, alternatively, perhaps an amp under the seat or even a modulator that attaches to the antenna-in connection...anything that can be jacked into...anyway, if I can do that part of it cleanly, then I would use an iPod or similar 20 or 40GB MP3 player and use that as my input...no storage problem with disks or tapes, fewer worries about some worm breaking into your ride to steal a fancy radio, take your tunes with you when you park your ride, more music than can be listened to in a lifetime, etc. Those are my thoughts... |
#19 |
i love this. Plus it has outs for a cd changer later on.
1972 k10 4x4 LWB (Sold in 2005 ![]() |
#20 |
Dumb Question...
What is that blockout plate immediately above the heater/A/C controls for? I don't recall seeing that in the stepside we just bought...
#21 | |
Member since 2000
Re: Dumb Question...
#22 |
Ash Tray...
Do all the models have those? Again, I don't emember seeing that in our truck, but then the older I get the more I forget...
What were we talking about? ![]() |
#23 |
now thats a true COON DOG
![]() Join Date: Nov 2000
Billogna- Thats a sweet looking cnsole you've got there! I agree with the other, more info on how you made it or where you bought it would be real cool! Printed them up so I could make my own!
current project 67 ![]() 71 SWB Stepside, was a 250, now is a 402 Big Block with 4 speed and 3.73's ( was crushed by a tree, bed sold, motor pulled) ![]() 72 LWB 4x4 350 4-speed 3.08's posi wearing army olive drab green (SOLD!) 68 BURB 50TH LOOKALIKE work in progress, soon to have 250-I6 with a 3-speed on the tree 4.11's and posi ( currently sitting in back yard tarped awaiting time, $$$, and lots of love!) 67 1 TON- work truck 396 sm 420 4-speed, flat bed 4.57 gears "big red" (my first landscape truck, very rusty and crusty! but still gets the job done when needed!) |
#24 |
console
Stepsides4Ever and others: I made cardboard templates for the sides first to get an idea of the shape of the floor, then used 3/4" particle board, glued and screwed together with wood screws, seams and screws covered with wood filler, covered in drywall texture from a spray can, then spray painted with semi-gloss black. The thin black carpet is from Autozone ($10 a roll), and the oversized cupholders are from a marine parts store ($6 ea). I used wood screws through tubing to make the pins for the door, and it follows a routed groove on each side down behind the radio. I have clips holding it to the underside of the dash, (no holes drilled in the truck), to keep it secure when having too much fun in the turns. Hope this helps.
#25 |
Stepsides 4Ever
Sounds like you won't even need a console- if you install the original looking radio in the dash, (with an aux input) just put the ipod, or whatever in the glovebox. All of your controls, except to switch songs, will be right on the radio.
