Old 02-11-2004, 09:27 PM   #1
WestCoaster
Junior Member
WestCoaster's Avatar
Swap 70 PU Cab to a 1990 Sub 4x4
Hello
I have access to a 1970 PU Cab and Frontend. There is no frame or bed, however I have gone through all the points that habor rust in this vintage truck and there is none. The farmer has it stored in a hay barn, several in fact.
I have a 1990 4x4 Suburban, solid front axle with a wheelbase of 127, that is a great daily driver that I am considering making into a donor chassis for the 1970 PU.
Is this possible? What are the biggest issues that I will face? Has anyone done this?
Thanks for the time.
WestCoaster is offline   Reply With Quote
Old 02-12-2004, 01:23 AM   #2
Prerunner1982
Prerunner1982's Avatar
the body mounts may not be right on... also i dont believe the wheel bases will match up either. no big deal if you are considering a custom flat bed. i know i WILL be corrected if i was wrong.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 02-12-2004, 10:46 PM   #3
racedvl
racedvl's Avatar
If you can weld, the world is yours!!!
racedvl is offline   Reply With Quote
