Old 02-12-2004, 12:59 AM   #1
angelsairman
Future Owner
angelsairman's Avatar
alternator bracket question
On my 71 c10 350 with a short water pump and Internal Alt, when i install the belt the alternator sits only maybe .25 inch from the end of the top bracket and the alternotr also seems to be sitting awful close to the valve cover. The bottom of the top Alt bracket looks to have been hacked on by a previous owner im wondering if maybe they didnt shorten it for some unknown reason(it was a farmers truck in ND). So what i guess im asking is it normal for it to sit so close to the Valve cover and be so close to full adjustment??? Thanks in advance
Its not the end result that counts most...its the journey along the way that's most rewarding
My truck doesn't leak, it just marks it's territory
angelsairman is offline   Reply With Quote
Old 02-12-2004, 01:30 AM   #2
jorgensensc
jorgensensc's Avatar
post some pics if you can.
When I put a new belt on mine, it sat pretty close to the valve covers, but once the belt stretched out it was further away(after I readjusted the belt). Hope this helps a little.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 02-12-2004, 01:38 AM   #3
rage'nrat638
rage'nrat638's Avatar
here
rage'nrat638 is offline   Reply With Quote
Old 02-12-2004, 01:42 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You might just get a new one if someone has screwed yours up.
GM part number 460754. Cost about 7 bucks nowdays. See your friendly dealer.
Old 02-12-2004, 02:12 AM   #5
gr8scott51
gr8scott51's Avatar
check out www.alangrovecomponents.com for options.
scott
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
