02-12-2004, 03:53 AM | #1 |
help with starter wiring
Hi guys, i had an engine fire last year, and I finally got all my wiring patched back up. The only thing i can figure out is what the small wire on my starter should go to, can anyone help me out?
thanks
3/4 ton 71 GMC 383 Stroker |
02-12-2004, 04:26 AM | #2 |
Black 72 Chevy
Connect 12V battery cable to the large pole with nut of the seloniod and there also is a purple wire that goes connected there. Check the diagrams. The purple wire goes connected to the ignition switch.
http://www.geocities.com/chevroletc1070/wiringdias.html A.P. Hope this helps. |
02-12-2004, 04:33 AM | #3 |
The yellow 20 ga. wire? That goes from the starter solenoid to a splice in your firewall wire gutter, from there it splits, one wire goes to the positive side of your ign. coil, and the other purple/black wire is a resistor wire running to your firewall connector. If you've upgraded to HEI, you should replace this p/blk resistor wire segment with a piece of 18-20 ga. wire. I hope this is the answer you were looking for.
-Sam PS: A.P's link above shows the resistor wire color orn/ppl, however my 72 diagram shows it being ppl/blk
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. Last edited by Sweet72; 02-12-2004 at 04:39 AM. |
