Old 02-12-2004, 11:50 AM   #1
Nightrider
Nightrider's Avatar
coil to leaf?
Whats involved in converting a coil spring rear end to leaf rear end? Seems like I have plenty of one but not the other. thanks...
] : - 71' burb,5.3,4wd
02' f350.7.3
00' F250-powerstroke
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Nightrider is offline   Reply With Quote
Old 02-12-2004, 03:31 PM   #2
MrGoodpliers
MrGoodpliers's Avatar
Just the removal of the rivets on the brackets of your leaf donor frame and bolting them up on your coil frame (after you remove all of the coil related stuff )
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC...
MrGoodpliers is offline   Reply With Quote
Old 02-13-2004, 10:16 AM   #3
Nightrider
Nightrider's Avatar
I should have known it was that easy, thanks for the tips!
02' f350.7.3
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Old 02-13-2004, 10:19 AM   #4
Bowtie67
Bowtie67's Avatar
Post
Just one quick little thing here is depending on what vehicle this is, I think 71 and newer had wider axles, this may be the only real issue, if you are pulling existing axle setup out of a leaf unit, you will probably be OK. Just a FYI..
Bowtie67 is offline   Reply With Quote
