Old 02-12-2004, 12:43 PM   #1
chevy garage
chevy garage's Avatar
Question Is there a difference in master cylinders?
I running new brake lines on my 70 for manual disc conversion. The two lines from master cylinder to proportioning valve are not lining up. I bought a new master cylinder for a 71 and the line inlets measure 3". The distance of the new line spacing is +/- 4.25". Am I using the wrong master cylinder or not?
chevy garage is offline   Reply With Quote
Old 02-12-2004, 12:48 PM   #2
MrGoodpliers
MrGoodpliers's Avatar
The '71 master cylinder should work fine. More importantly, you need a disc brake (71-72) proportioning valve.
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC...
MrGoodpliers is offline   Reply With Quote
Old 02-12-2004, 12:54 PM   #3
chevy garage
I thing I have the correct proportioning valve. I bought it from our local GM dealer and it looks like others I have seen. I don't know what the problem may be. I noticed a different looking master cylinder in the Early Classics Catalog. It looked like the line outlets on the master cylinder were further apart,which is what I need. Our local parts stores only show 1 listing for 71 pickups with disc brakes.
Old 02-12-2004, 01:35 PM   #4
boraxman
Keepin an eye out
boraxman's Avatar
If youre using Inline tube lines they wont match up to the stock prop valve. I ended up buying one of their prop valves, but I havent got it yet....so we'll see.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
