Keepin an eye out
Disc brake rear set-up (Ebay)
http://cgi.ebay.com/ebaymotors/ws/eB...category=42605
Got this from the 73-87 parts board...but it will also work on our year 5 lug rears.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
he said he used 79 -85 calipers. i thought you needed 76-78. or is that just for 8 lug?
Large Member
![]() Join Date: Jun 2002
For those of us on budgets, there are a few guys on ebay that sell the blueprints for the bracket that holds the rotors, and gives everything you need in part numbers to make it work.. The blueprints run about 20 dollars from what I have noticed.
Frank |
Merciless Butcher
I bought a set of those on ebay. They are pretty complete and the detail is pretty good. The suggestion is to use rear calipers from a late model Camaro. The price for rebuilt calipers is not that bad until you see what they want for a core charge. You could almost get a set of Wilwood's for the same price of the Camaro calipers and the core charge.
Your Bought And Sold....I Got Your Soul! |
Large Member
On those plans gonebad2, what rotors do they suggest? I was about to buy the plans .. well i have about bought them several times lol, but im just wondering if its worth it or not
does it say in the kit if the axle flanges need to be turned down to fit inside the rotor? if anyone has a need for the cad calipers i have a good supply of used ones for cores. they could probably be used as is and if bad are worth more than i charge when used as core. not setting a price till i know if there is enough interest to make it worth my while. i can also get used rotors and proportioning valves.
