Tachometer power.
Where in the fusebox should the tachometer be plugged in? IGN UNFUSED?
Thanks |
On my truck i have it in igfn unfused but i put a inline blade fuse holder after that with a 3 amp fuse for just in case Because fuses are cheaper than those high dollar autometer tachs
![]() ![]() Last edited by 1972C10; 02-13-2004 at 02:42 AM. |
go bucks!
anywhere that you have switched power source (ignition key on) and make sure that you do this right....if not you'll be like me and wonder for 8 to 10 months where you got a battery drain coming from! i had mine hooked up to constant power source.......dduuuhhhh!!
'68 swb 1/2t 350/350th '86 lngbd 3/4 TON parts getter '49 gmc 1/2 t 5 window 350/350th '96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know? |
