02-13-2004, 10:33 AM | #1 |
Silverado Stew
Need Opinions (Advice)
I have a '79 350 that blew a gasket and sucked all my antifreeze into the oil pan. Now I have a friggin' chocolate milkshake to deal with. My questions is: Should I run something like auto transmission fluid through the motor to help clean it out, or just change the oil and run it for a little bit, then change it again?
- 1997 3/4 Ton Ext. Cab LB 4x4 6.5L Diesel - 1979 3/4 Ton Longbed 4x4 "Farm Truck" - 1984 1/2 Ton w/ '99 Vortec 350/700R4 2x4 FOR SALE |
02-13-2004, 10:54 AM | #2 |
You get what you pay for
I would remove the oil pan and clean it out. Then put in fresh oil and filter. Start it up and run it til it gets warm. Drain it again and new oil and filter. Run it for 500 miles or so, and change the oil and filter again.
I suggest doing this pretty quick before rust starts to form on the cylinder walls, which only takes a day of so.
Mike 1985 Chevy C-10 |
02-13-2004, 08:18 PM | #3 |
driving is in my blood
Id just drain the pan for a couple hours, run a few quarts of good oil threw it for a minute or two, then drain, refill and dont worry about it.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
