#1 | |
Bloo
ok my dad has a 89 4x4 and the rght door will not close tight with out bieng slammed very hard. what makes it that way?!?!?!?!?1
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
Vortec 350's Suck
It is the pins and bushings in your doors that are worn out. Change the door pins and bushimgs which is a pain in the ass because of the design of the door spring and the problem will be solved.b
------------------ 69 CST, 402 steel crank, heavy rods polished ported heads 2.19/1.88 should be 450+ 700R4 373 Posi buckets/console air/tilt/tach 4wheel discs Daily Driver: 92 Chev 4x4 350 Accel filter/cap/rotor/coil Edelbrock intake and headers true duals Helix TBI spacer stock 700R4 for now!
69 Chev CST 10 reg cab lwb Daily Driver: 92 Chev Reg Cab LWB Silverado 4x4, K.I.A 7:51 AM 04/22/03 Will be resurrected |
#3 | |
Bloo
so could i just replace the doors? i want to ne way so would this be a good enuff reaason 2?
#4 | |
Bloo
ttt
Vortec 350's Suck
Sorry for not responding but changing the doors are entirely up to you. Provided a donor trucks doors may be just as worn out as the ones you have. It is not that big of a job to change pins and bushings so it is really not neccessary to change the whole door unless there are other things wrong with them like dents, rust or whatever.
------------------ 69 CST 10, 402, steel crank, heavy rods polished ported 781 heads 2.19/1.88 manley stainless valves, Crane Powermax Hydraulic roller 288/296 and .587,.610 lift, hardened pushrods, Crane Roller Rockers, Weiand Action Plus, 750CFM Edelbrock QJET, MSD HEI should be about 500 H.P. 700R4 2500 stall, pretty nasty shift kit, 373 Posi buckets/console air/tilt/tach 4wheel discs Daily Driver: 92 Chev 4x4 350 Accel filter/cap/rotor/coil Edelbrock intake and headers true duals Helix TBI spacer 700R4 with B@M Shift Kit for now!
#6 | |
Bloo
well there both dented and really scratched,,so maybe i could get some new paint and not have to slam my door
| Bookmarks |
