Old 02-14-2004, 08:05 AM   #1
Mike76251
Cycle your A/C.
Next time you get in your truck............turn on your AC for a few miles or minutes.
Gotta lube the ole' compressor.
BTW........if you don't have AC in your truck, don't do this!! LOL
Mike76251 is offline   Reply With Quote
Old 02-14-2004, 10:57 AM   #2
Blue Beard
Blue Beard's Avatar
In the dead of winter.........?
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 02-14-2004, 11:15 AM   #3
swervin ervin
You get what you pay for
swervin ervin's Avatar
Mike,
you do come up with decent ideas every once in a while.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 02-14-2004, 12:06 PM   #4
Mike76251
Yes BlueBeard even now.
I work on AC systems and can tell you one thing........people that do make alot of money at the start of the summer because people don't do this.
The front seal don't get lube unless you cycle it on and if it dries out then bye-bye freon.
If you ever notice that oil stain on the inside of the hood right above the compressor...........that's the oil lost through the front compressor seal. It is a "oil loss" type lube setup.
If that oil stain on the hood is heavy it also wouldn't be a bad idea to add a little oil to your system every year or two.
Old 02-14-2004, 12:14 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Cycle your A/C.
I never turn mine off. It stays on year round on all my trucks. If I want heat I adjust the temp, but the a/c stays on...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-14-2004, 12:25 PM   #6
Mike76251
I don't doubt it N2Trux,
(I spent some time in Houston not long back)...........I DO NOT miss 100 degrees and 100% humidity!!!!!!!
Old 02-14-2004, 01:00 PM   #7
Grim Reaper
Thanks for the reminder. I knew you were supose to do that but it had not crossed my mind to do so. I'll run it today.
Here is another reminder. Beat your fire extingushers!
Yep the vibrations from being in a vehicle in particular will cause the powder to pack. If you pull it out and turn it upside down and feel a light thud that is a extinguisher that the powder has packed. Shake it and spank it to get hte powder broken up.
My buddy is the head maintance guy at a local hospital and the monthly go and turn over all the fire extinguishers in the building to make sure they have not packed.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 02-14-2004, 01:01 PM   #8
rage'nrat638
rage'nrat638's Avatar
well if you turn on the defroster i hear the a/c comp. clicking in and out....is this not the same thing?
rage'nrat638 is offline   Reply With Quote
Old 02-14-2004, 01:31 PM   #9
Grim Reaper
Yep that will do it. I have had mine on Heat for the past 2 months and no A/C in that posistion.
Grim-Reaper
Old 02-14-2004, 04:49 PM   #10
BladeX
not to steal the post or anything but say you deystroyed your compressor whats the chances of finding one at a junk yard?
I know at my work they are like 300 dollars so.. yeh.
BladeX is offline   Reply With Quote
Old 02-14-2004, 06:43 PM   #11
Lynx
Lynx's Avatar
Excelent idea! I know from personal experiance that this is the thing to do!
My mom never used her A/C on her 1997 caravan, but when we did use it we notice that it was not cold and running low, well it started getting cool outside so she decided to wait till the summer to fix, well big mistake! We were cruizing down the highway at 120km/h and all of a suden we get this HUGE grinding awful sound so we pull over and smoke pours out from under the hood. I thought somthing major happend and since we were about 100km from any town i was pretty pissed. But after fiddling with it and noticing that the sound cut on and off with the copressor i figure out that if you just turn off the airfan we were good to go. just without heat....
Also it was not a cheapfix.... needless to say we use the a/c alot more often now!
Ben
1983 Silverado SWB 305
2002 Silverado Extended Cab 5.3
http://members.shaw.ca/bkennett
Lynx is offline   Reply With Quote
Old 02-14-2004, 08:18 PM   #12
1985K10
1985K10's Avatar
I guess having the belt off for the winter won't help!
Anthony
07 Tahoe LT
70 Chevelle 450HP 383-TH400
77 GMC Royal Sierra~Resto in progress~
1985K10 is offline   Reply With Quote
Old 02-15-2004, 12:20 AM   #13
Mike76251
I would not EVER advise anyone to buy a junk-yard compressor because they would probably be full of acid that would destroy the rest of the system.
Where does the acid come from? When you mix freon with air it creates Sulfuric acid. Simple chemistry.
Never buy one from a cheap parts house either.........I once got a AutoZone compressor and it took 4 before I got one that wasn't locked up. Try filling your R12 system 4 times because of bad compressors................14 cans at (now) $50 a can! Good thing Freon was cheap then and I have a license to buy it.
Old 02-15-2004, 12:25 AM   #14
Mike76251
Be sure you don't try to run the compressor if it's cycling like that.........the low pressure switch cuts it out like that to keep you from burning the compressor up.
No pressure in the system means no Freon and no Freon means no oil to lube that compressor.
How long would a engine last with no oil? That's all a compressor is........a small engine.
Old 02-15-2004, 01:14 AM   #15
apstguy
LED King
apstguy's Avatar
Where would you reccomend getting a new (or rebuilt) compressor? A new one from the dealer is $700!!!!
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 02-15-2004, 01:49 AM   #16
rage'nrat638
i have the one off my 85 c-10...if there's any interest...p.m. me
Old 02-15-2004, 04:52 AM   #17
jimfulco
[QUOTE]Originally posted by Grim Reaper
Yep, it's a sick feeling when you try to use your fire extinguisher & it just belches & farts a couple of times and then dies. I was lucky, there was a ditch full of water ten feet away, & it was not a gas or oil fire.
jimfulco is offline   Reply With Quote
Old 02-15-2004, 04:02 PM   #18
Grim Reaper
[QUOTE]Originally posted by jimfulco
I bet!
It's actually better to mount them laying down or upside down. That way the powder doesn't pack around the inlet tube (as bad) and when you shand them up the get a little shake. The hope is that it's enough to break it up so it works.
Grim-Reaper
