Active Member
Bed Swap
Have just about decided but thought I'd get some opinions.
Can't decide on which bed to put on truck. Here it is with 92 ss bed. Need to do some adjusting.
69_67_92 C-10 Drivable/Under Construction 2002 Impala 1999 Toyota 4-runner |
Active Member
Here is a pic of the bed I pulled off. Only thing I don't like is the
cut-out for spare. Bed dent/rust free. I have removed rotten wood bed bought new stainless strips,lights,chains etc from LMC but when son wrecked his truck I was talked into trying his bed?
Active Member
Also if I use new or old bed I want to relocate fuel tank to
underneath bed. Have seen several threads on doing this just can't decide which way to go. Leaning towards using a blazer or camaro tank. I also pulled 350 out of totaled truck and plan on using it. Have new fuel sending unit that goes in tank so I'll need a tank that will fit in or another option. Looks like evertime I start something here I open a whole new can of worms.
its all about the +6 inches
Personally, i would sell the late model bed, and run the stock one. Short steps flat out rock.
I agree completely.
I totally agree. I would run the stocker and sell the late model. By the way. Once upon a time, I ran a S10 gas tank inbetween my frame rails in the back and the install was very easy. It fit perfectly between the rails and only needed straps to hold it in from the bottom. I saw you mentioning the tank and am not sure which ones people have suggested, but I know that works. It was from an older S10 because I did that back in the 90's
Tom |
67-72 Addict!
Personally I like that later model bed- Tubbed!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
FUEL CELL GURU
Dump...
the late model bed. Stick to the original bed. It looks much better. I wouldn't be able to stand looking at the two different wheel openings. OR use the late model bed and change the wheel opening. Later, FCG
Active Member
Hmmmmm, 3 to 1 so far on keeping orig. bed. maybe I could
either get a new fender for cut out or some kind of filler plate. Might have to look into that. Basically I need to get it all one color but not gonna finish painting til I decide. Thanks Don
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I would try to make the late model bed wheel well's fit the truck first and then swap the bed's. I f that did not work you could alway's use the stocker bed..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
computer illiterate
i would replace the cut out fender and run the origional bed
72 2wd blazer 72 swb 4x4 |
Designated A-hole!
Go with the original! You can't beat a short stepside. The lines on the late model bed just don't match without a lot of work.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
![]() ![]() Join Date: Jul 2002
Don
I like both, but I prefer the original bed. Your's appears to be in better shape that what I started with, so it shouldn't be too bad to get it looking good. I am also one the says keep the spare cut out! Be different and have the spare in a convienient place. Give it that nostalgic look. Don't know how fast they sell up in Jackson area, but the late model beds don't move real fast on the coast. Far as an out of cab tank, one of the blazer kits or have a fuelcell made for it. I don't think the camaro's fit in the frames very well.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 02-14-2004 at 01:12 PM. |
#13 |
Original Bed... Without Question!!!
1972 CHEYENNE SUPER SWB BLACK. 402 BB, TH400, AIR, TILT, TACH, BUCKETS, CRUISE, AM/FM, 8 TRACK. My build thread: http://67-72chevytrucks.com/vboard/s...=1#post7120181 |
#14 |
Unregistered User
![]() Join Date: Dec 2001
Another vote for stock - but I also prefer no spare cutout. If the rest of the bed is good, I'd try to find another fender.
Mike
71 SWB Stepside SB400/TH350 |
#15 |
454 club
I like the stock bed. I had the spare cutout. I like it. It really depends on how you want it to look.
David 1965 Chevrolet c-10 454 automatic Custom bbw swb. 1965 Chevrolet C-10 swb (Sold) 1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's. R.I.P "I will miss you. 1967 Chevrolet C-10 6 Cyl Custom lwb 1939 Chevrolet Coupe, 350 v8 automatic. 1935 Chevrolet 2 Dr Standard in the works. 2015 Harley Davidson Street Glide. 2023 Chevrolet Stingray Z51 Convertible. I never want to grow up. |
#16 |
Working on a Nova.
Go with the late model bed so you can give me the old one! I like the old bed better and if you use it then I couldn't get it from ya! oops!! I think I said too much.
#17 |
The thought crossed my mind too gloryhound
#18 |
Born To Lose Club
![]() Join Date: Feb 2003
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
I vote Stock Box Too...I personally don't have much a problem with the spare cut out fenders but it would look cleaner without a spare sitting there. Even with a newer Stepside box, If i had a pretty decent Stock Box (which it looks you have) I would be trying to make that work first.....
Brian Smith ![]() 1969 Chevrolet K10 LWB Fleetside - Proud Owner For 20 Yrs - 1 of 208 Built & Sold In Canada! - 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's. 1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 2 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds 2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 15 Yrs - 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's. 2008 Yamaha Raptor 700r - Proud Owner For 13 Yrs - ITP Mud Lites. 2015 John Deere 1025R - Proud Owner For 6 Yrs - 24HP Diesel/H120/54D/260B/SB1154. |
#19 |
You cannot go wrong with stock. Sell the new bed and use the money to fix your old bed!!!!!
#20 |
I vote for keeping the stock box and getting a different drivers fender. I have a friend up here that may be interested in your modern step bed, or at least the passenger bedside for his 91 4X4 with a chunk out of it from a tree. What are you asking for it?
#21 |
I say sell them both and get an original fleetside box for it they look the best.
69 Chevelle (Summer only ride, love to drive this) 72 Chevy Shortbox 4x2 (newest addition) 83 Chevy Shortbox 4x2 (project but its clean) 2001 S10 Ext. Cab 4x4 (daily driver) |
#22 | |
Bloo
i say new bed, but either way you go, if you sell the original's fender i may be interested (or in both and the front panel if you use the new bed)
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
#23 |
Keepin an eye out
Original.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
#24 |
IT COMES DOWN TO ORIGINAL OR CUSTOM. I PERSONALY DO LIKE THE LATE MODEL BEDS.
#25 |
huh ???
I'd stick with the original bed. I think the late models on older trucks look like s*(&...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
