02-14-2004, 05:00 PM | #1 |
Transmission Crossmember
Hey,
Well it's come time to start putting my truck back together, and I need to know where to mount my transmission crossmember. It's a 350/350 combo, (auto transmission), and the engine will be in the stock v-8 location, and I was wondering which holes the it mounts in, there looks to be about 3 places that I could mount it. I know the general location, just can't figure out holes to use. Thanks! Brian Pal BTW: my 900th post
Brian Pal 1971 Cheyenne 10 454/th400-Undergoing a full frame off resto. 1972 Chevy short/step 2wd, 350/th350 1983 M1009 CUCV Military K5 Blazer 1981 Dodge 1 ton 4x4 dually flatbed |
02-14-2004, 05:13 PM | #2 |
Designated A-hole!
The way I do it is put the crossmember on the frame but farther back than it needs to be, then drop engine and tranny in and slide crossmember into place. Let the tranny rest on xmember until you get the motor mounts bolted up (easier to move around to get motor mounts lined up). Then bolt crossmember to tranny then bolt to frame. Hope that helps.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
02-14-2004, 05:14 PM | #3 |
Dont put cross member in till you have the transmission, then you will be able to find which holes to use of end drilling new holes like I had to.
