help installing kickdown cable
Im replacing the kickdown cable on my turbo 350 tranny and it looks like its gonna be a pain. Is there any trick to getting that little hook that it attaches to in the tranny out of the old cable and back into the new, and is a bunch of fluid gonna run out when i remove the old one?
3/4 ton 71 GMC 383 Stroker |
Drop the pan.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03) 1998 S10 short bed 2002 S10 Blazer 1942 Oldsmobile 1958 Massey Harris Pony 1951 Wife Killingworth, Connecticut May those who love us, love us, any of those who do not love us, may God turn their hearts. And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping. A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist. |
its all about the +6 inches
Drop the pan and you'll be abble to hook it up no problem. May as well get a tranny filter kit while you're in there.
You can hook it from the hole it goes into, but you'll be under there for a few hrs and you'll invent new cuss words. |
pull the cable housing from the tranny, then pull the housing up on the cable exposing the inner cable and then pull the inner cable ......the small wire arm will come up out of the tranny hole exposing itslef, you can take a small pair of needle nose pliers, hold the wire and remove your old cable, install new cable.
If you dont drain it, you will get a large amount of fluid on the floor. when you pull the cable housing. |
