60' times at the track?
Hey, im thinking about putting a truck arm type suspension on my 83 C10 shortbed and was wondering what kind of 60' times you guys w/ these setups stock have ran at the track....street tires, slicks, whatever.
thanks ![]()
83 Monte Carlo 92 Camaro |
Few years ago with a flat top 350 and rv cam i was running 1.99 Or something close to that. havent had a chance to hook with the new setup Ill post up some times when the weather is dry and i go run it Should be very soon.
If your thinking of putting a 67-72 trailin arm setup you would be better off with a 2link or 4 link these trailing arms are LONG! thats the cause of some of the non hook problems |
trailing arms
I can tell you with total certainty that trailing arms are not a problem, they are a blessing. I have had 1.25 60' times with them and have been able to get down tracks when competitors cars were smoking the tires. This was obviously with a different motor/trans combo than is listed in my sig. I would never take them off of my truck for racing. It's all about the spring rate, the pinion angle, etc.
No more dragtruck for me. I'm building a new ride though. It's a '71 fleetside, 400 sbc, 700R4. Working on it now, finally. Soon to have Edelbrock Pro Flo EFI, Vintage Air, 1 piece windows, buddy buckets, etc. My new build thread: http://67-72chevytrucks.com/vboard/s...17#post2861817 Best pass with the old dragtruck: 5.32 @ 131.6 mph 1/8 mile w/ a 1.25 60' Fogger/Plate 2003 Best pass with the street 406 hydraulic roller motor w/ mild plate tuneup 5.93 @ 114 mph 1/8 mile w/ a 1.29 60' 2003 or 2004 |
thats the type of thing i was hoping to hear. by the way..since this is a custom install, does spring perch position have much effect on launching? Ive seen truck trailing arme setups w/ the lower spring perch on the trailing arm but have also seen the lower perches on the rear end.
#5 | |
Tom
im talking about the lower coil spring perch, not the trailing arm perch. I know that obviously has to be welded to the rear. Do you see what im asking?
this type of spring setup ![]() vs. this type of spring mounting setup ![]() as a side note, i dont plan on buying any of the overpriced setups pictured above. they (hot rods to hell) must think these things are gold plated ![]()
i see
I do see what you mean now. Sorry. I dont' think that spring placement really makes that much difference. It can make a difference in what spring rate is required due to the different leverage enacted on the spring based on it's placement. The shock location can definitely make a difference.
Tom
60' foot
Jon
I have a mild small block and 12.5inch MT Sportsman pro tires so far my best 60' has been a 1.97. I like the trailing arms and I think they work well! I would just use a coilover shock instead of a coilspring! My truck weighs 4016 lbs with me in it!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
hey tom, do you have any pics of your truck during its build up that you could email me? id be interested in seeing your front suspension setup and roll cage.
ran out of money
link
jon_volk- does that co. have a link, i would be interested in what the kit looks like and what is included in it. not saying i would buy it, but i am more then likly going to redo my rear suspension or buy a shorty frame and build up the rear suspension for that..
Thanks Rat
Modify everything, leave nothing alone!~ ![]() ![]() |
ran out of money
thank you
#13 |
1.65 60' on a 11.5 1/4 mile pass
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
#14 |
If you need some pictures let me know. I have the kit and I'm supposed to be getting some pictures for Primed67. It's not installed yet but should be within 2 months.
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
#15 |
ran out of money
pics
68lss1: if you can post pictures of your build that would be great, i am very interested. and what does the kit include that you bought?
Thanks Rat
