Old 02-15-2004, 07:42 PM   #1
pissonNOS
senior member
pissonNOS's Avatar
lowering blocks for rear ?'s
well I want to lower my 69 and want to put some blocks under the axle in the back so anyone have soe sizes or ideas how to build the blocks for the back? I want to go 3 front and 4 in the rear so how tall of a block do I ahve to use for the back to get it 4 inches lower and also what else should I do in the back to get it this low or is blocks good enough. For the front I;m just going to cut the coils till I can get some dropspindles.
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 02-15-2004, 08:20 PM   #2
Oborny71
Oborny71's Avatar
for the front, you can just cut the coils. 1 1/2 rounds off should give you a 3" drop, don't go any more than this without drop spindals. For the back use some solid pieces of metal for lowering blocks, your prolly gonna have to weld a few pieces together for the lowering blocks. I would NOT go more than 2" on the lowering blocks. To get 4" total, your gonna need to get springs. What i did is used car springs out of a late 70's/early 80's monte carlo, chevelle, ect... they fit without any modifications and give you a 4" in. drop wihtout lowering blocks. good luck!
67 Chevy SWB - goal of a 1,000 hp weekend cruiser
Oborny71 is offline   Reply With Quote
Old 02-15-2004, 08:28 PM   #3
Gene
Gene's Avatar
I made mine out of 3 inch aluminum blocks, steel will work just as well. You will also have to have longer U-bolts made or you will have to buy some. I agree, I wouldnt go with 4 inch blocks. To get more I would go with springs also.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 02-15-2004, 08:30 PM   #4
pissonNOS
senior member
pissonNOS's Avatar
so your saying you just put these spring in and it lowered it 4 inches?
69 GMC bagged
Old 02-15-2004, 10:38 PM   #5
Oborny71
Oborny71's Avatar
yup, it lowers it about 4" with just the springs. The spring retainer cups from our trucks work perfect on these springs, no modifications are needed. The springs are a lot softer than the regular truck springs, because they are car springs of course. If you are going to be hauling anything , i would recommend you get regular truck lowering springs.don't remeber exactly what car they were out of, but i'm sure someone else here knows who has done it before. I like them for racing at the track, because they have a lot of give and provide for good weight transfer.
Old 02-15-2004, 10:41 PM   #6
Blue Beard
Blue Beard's Avatar
Take the measurements you need after building the blocks for the u-bolts.....
Had mine done and worked great.........
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 02-15-2004, 11:59 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
With the A/G body rear springs, how is the ride? How does it corner?
Old 02-16-2004, 12:03 AM   #8
Randy70C-10
Randy70C-10's Avatar
How your truck handles while cornering all depends on how good your shocks are.
Randy70C-10 is offline   Reply With Quote
Old 02-16-2004, 01:49 PM   #9
Oborny71
Oborny71's Avatar
longhorn - the ride is great!. most people can't believe how smooth my truck rides for a lowered truck.
Old 02-16-2004, 08:16 PM   #10
Longhorn Man
Hmmm, maybe I need to hit the junk yards.
Old 02-16-2004, 10:04 PM   #11
bad69
Struggling Artist
I've got chevelle springs new in box if you need some. I used 4" lowered truck springs and 2" X2" STEEL STOCK AND DRILLED THEM FOR A 6" DROP.
69 1/2 ton lwb lowrider
90 C-1500 2wd
08 2500 HD 4WD
94 Grand Cherokee
49 Cadillac sedan
bad69 is offline   Reply With Quote
Old 02-16-2004, 10:33 PM   #12
pissonNOS
senior member
pissonNOS's Avatar
any pics of your drop blocks anyone?
69 GMC bagged
Old 02-16-2004, 11:58 PM   #13
MellowYellow70
Sorry for the lighting, but its 12 degrees outside and about 8 in my shed. I've got 3 inch drop springs and 3 inch drop blocks with longer u-bolts. Truck (when was possible) rode on toxic drop shocks and it was a great ride, hooked like a mofo as well.
If patience is truely a virtue, Then I am so screwed
1970 Chevy SWB Gasser 364"LS and all the goodies
2001 Vette Road/Street
1990 IROCZ Vert
MellowYellow70 is offline   Reply With Quote
Old 02-17-2004, 12:16 AM   #14
racedvl
racedvl's Avatar
These would be the rear springs, or the front?
racedvl is offline   Reply With Quote
Old 02-17-2004, 01:05 AM   #15
Longhorn Man
That's for the back...lowering blocks wouldn't work well in the front.
...they fit without any modifications and give you a 4" in. drop wihtout lowering blocks...
Old 02-17-2004, 10:24 AM   #16
racedvl
racedvl's Avatar
No, no, I mean, the car springs. Would I look for front car springs, or rear car springs.
Hi, I'm looking for a set of _________ (front,rear) coil springs for a 1979 montie carlo.
Old 02-17-2004, 10:34 AM   #17
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
2 inch rear blocks
Old 02-17-2004, 01:03 PM   #18
pissonNOS
senior member
pissonNOS's Avatar
great pic TX
69 GMC bagged
Old 02-18-2004, 12:31 AM   #19
Longhorn Man
Ahhh, I see Jason.
It would have to be the rear springs off the G/A body, they are pigtailed liek ours are, the front springs would probably swap right in up front too, but that is just speculation on my behalf.
A/G body cars would include Malibu, cutlass, Grand Prix, El Camino... I think there is another one, but I can not recall it at the moment.
Old 02-18-2004, 12:32 AM   #20
Longhorn Man
Regal and Monte Carl, there. I think that's all the A/G cars.
Old 02-18-2004, 12:38 AM   #21
jamis
F.A.S.T. president
jamis's Avatar
just like Tx said. 2X3 square 1/4" wall tubing and weld some caps on the end.
jamis is offline   Reply With Quote
Old 02-18-2004, 12:55 AM   #22
barn9
Half a bubble off!
barn9's Avatar
I lowered my back end using a kit from Godfather's Customs that cost (at the time, not sure now) $19.95. It came with the longer U-bolts, and a set of steel blocks (4 per side -3/4" each block-in the set, but you could use however many suited your taste). I couldn't find longer U-bolts for less than what the kit cost me. Most of the aftermarket catalogs have these kits at a reasonable cost, makes for a nice and easy way of lowering, and everything fits. A friend of mine decided he could make his own cheaper, but learned the hard way it wasn't so cheap, and then struggled with the U-bolts fitting through the blocks he fabbed. I had the kit installed in a little over an hour, and I wasn't hurrying.
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 02-18-2004, 01:44 AM   #23
pissonNOS
senior member
pissonNOS's Avatar
okay so im gonna make some 3"x3"x7" blocks now how low will this get me?
and up front im gonna cut the coils for a 2 inch drop so how much should I cut out of there? also I orderd belltech drop shocks for the front.
69 GMC bagged
Old 02-18-2004, 06:00 AM   #24
Gary
Gary's Avatar
I'm wanting to do a small lowering on my truck but so far everything I've found is $300+ a URL would be much appreciated
Thanks!
Gary is offline   Reply With Quote
Old 02-18-2004, 10:49 AM   #25
Z28Owner
Z28Owner's Avatar
I orderd a lowering block kit , 2 inches, comes with everything needed. Can anyone correct me If I am wrong? All I gotta do is jack up the rear and unbolt the ubolts then swap everything in there? Thanks.
1971 LWB Chevy C-10
350/350 3:42 eaton
Z28Owner is offline   Reply With Quote
