Old 02-15-2004, 10:26 PM   #1
stepside454
stepside454's Avatar
lowered- front tire clearance issue
I have a 75 C-10 thats been lowered with drop spindles, unsure of the drop.
I just realized how little room I have from the top of the tire to the inner wheel well. Theres only about 1.75"-2.0" of clearance.
It does rub occasionaly, like if I make a turn on a bit of a hill for example.
My concern is at speed, if I where to hit enough of a dip or bump in the road & it rubs, how disasteress could this be ?
Anyone else have a simialer situation ? is it a concern ?
John
75 GMC C-15 short/step factory 454, lowered
stepside454 is offline   Reply With Quote
Old 02-15-2004, 11:01 PM   #2
Senor_paco
didja get new springs? If so , get progressive, and thatr that way you can maintina your height without too much trouble. Otherwise with your c10, you cna put in 1 ton springs.
Senor_paco is offline   Reply With Quote
Old 02-15-2004, 11:15 PM   #3
TIMSPEED
TIMSPEED's Avatar
Re: lowered- front tire clearance issue
John
I feel your pain man...on my 75 C10, I put the DJM 3" Drop Spindles with 28" front tires..it'd work PERFECTLY...IF my springs were brand new. Since my passenger side spring sags like a mofo, everytime me and my buddies get in the truck, I CAN NOT make a sharp right turn...only one way to fix it..get some new springs, which is what I plan to do in the VERY near future.
BTW: If you have 2" of clearance you should be ok. I have 2" on my drivers side and I NEVER have any problems.
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 02-16-2004, 01:01 PM   #4
SCOTI
SCOTI's Avatar
My 74 rubs ('buzzes' the tires) on most big dips going down the highway. It actually rubs the top of the wheelwell (not the fenderlip). It hasn't caused any problems & has been driven since July 03 .
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-16-2004, 07:40 PM   #5
stepside454
scot, thats where mine would be rubbib, tops of the wheel wells. Thanks, John
Old 02-26-2004, 03:38 PM   #6
8t5Silverado
Mudslides 'r my specialty
8t5Silverado's Avatar
Will it rub because of the spring rate?
What if I had 2.5 spindles with 1.5 springs (Western Chassis) with 225/75-15s (28.29 overall diameter).
Will I rub?
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.)
http://www.cardomain.com/memberpage/500339
8t5Silverado is offline   Reply With Quote
Old 02-27-2004, 04:06 AM   #7
TIMSPEED
TIMSPEED's Avatar
Will I rub?
So 4" of drop with 28" tires (figure ¼" loss with weight)...I think you'll be fine. I'm going to TRY and run 4½" with 27½" tires...I want the fender-to-tire gap to be very minimal, while still remaning driveable.
See Them Here
Old 02-28-2004, 12:47 AM   #8
toytruck
5-7 dropped 87 CC Dually
toytruck's Avatar
Why don't you'all make the bump stops taller so the tire dosn't hit?
I rather be in my 77 Sanger Picklefork Jet Hydro!
toytruck is offline   Reply With Quote
Old 02-28-2004, 07:07 PM   #9
SCOTI
SCOTI's Avatar
Bumpstops
Well, on mine, if the bumpstop were taller than stock, it would contact the bottom of the c-member all the time.
The ones I currently use are trimmed down stockers (about 3/4 to 1" trimmed off). I'm going to replace them w/stock height bumpstops & that will cut down the rubbing considerably (I use a similar set-up on my 68 & it hardly ever buzzes).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
