MY EX DRIVES A BROOM
air ride help
which better buy an air bag kit or piece on together?
then get what from where? i'm in military and don't make a bunch of money any help is appreciated.
They say nobody's perfect. I'm a nobody, so I must be perfect. Building Nemo -1968 C10 Long Bed FRED -1947 KB-2 International |
fuel
![]() Join Date: Jul 2003
definetely piece it together. sooooo much cheaper, and get creative, when you go look for stuff go to truck stops, they have tons of stuff for air ride, remember big trucks use bags also. just make sure everything is DOT approved.
72 w/67 front clip 415ci fuel injection t56 air ride 18/20's |
Progress = 0%
Keep in mind that it's only cheaper if you are capable (and willing) to do some fabrication and know exactly what you need before you start the project. If you want a bolt on stuff that you can install in a weekend, then buy a kit.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
i was thinking something like ordering bags, brackets, and air pump. then going down to the local truck stop and see if i could find everything else there.
of course i still need to order sway bars and a longer adjustable panhard rod. money, money, money ![]()
Back from the Dead
You can do it seperatly for a lot cheaper. Just look all over the place for what you need. I was able to get most my fittings and lines from a truck shop. I did have to order the Valves and compressor from online businesses though. AS for bags and brackets I found them for cheap slightly used from a fellow boardmember. Just take your time and get what you want, its a lot nicer in the end.
The only Carb that matters to me is the one under my hood! Salem, Oregon |
Thanx for the help and info, I will post the stuff with prices and where it will come from as I find it to see if anyone can do better.
