02-16-2004, 12:49 AM | #1 |
BAD BOW-Silverado XST
Differential RPO codes deciferred!!!
02-16-2004, 02:45 AM | #2 |
But my truck doesn't give any information on the RPO sheet about any sort of gearing...
02-16-2004, 11:25 AM | #3 | |
Nice site for axle info.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
02-16-2004, 11:42 AM | #4 |
they also dont have the GQ1 rpo code, which is the standard axle... i assume its 3.08.. still a good site though
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
02-16-2004, 12:12 PM | #5 |
Insert Witty Text Here
My truck lists the gear ratio on the option sticker in the glove compartment. Most of the people with 80s trucks I have talked to have 2.73s.
Slonaker |
02-17-2004, 01:31 PM | #6 | |
Gentleman Jim Driver
For example the standard ratio for a 1984 1/2 ton 4x4 under 6500# GVW is 2.73 but a 1980 1/2 ton 2wd under 6500# is 3.08.
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
02-17-2004, 01:38 PM | #7 |
ahhhhhhhhhhhhhhhhhhhhhhhhhhhhh user text holds true again.
02-17-2004, 08:59 PM | #8 | |
02-17-2004, 09:02 PM | #9 | |
yeller
I give him an A for effort tho.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
02-17-2004, 09:50 PM | #10 |
The above codes would probably only be found on the build sheets.
02-17-2004, 11:27 PM | #11 | |
02-17-2004, 11:57 PM | #12 |
LED King
TIM - You wanna trade gears?
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
02-18-2004, 12:45 AM | #13 |
My truck had the following options
1: 305 v8 engine 2: 4 spd automatic transmission 3: standard gear ratio (GQ1 4: 31x10.5" tires front, rear, and spare 5: locking differential (G80) its an 1985 model shortbed 1/2 ton with a GVW of 6100 lbs, and it had 3.08 gears, talk about one retarded factory combo, OD couldn't even be used because it would only turn like 1600 rpm at 65mph.
1985 Scottsdale Shortbed 4x4 Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch. 2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle. |
