Old 02-16-2004, 03:51 PM   #1
aggiedave98
new springs vs. spacers for 2-3" lift
I've got an '89 suburban 1/2 ton 2wd. I'm looking at a 2-3" suspension lift. There's not much out there for me.
It's only got 113k miles on it.
What are the tradeoffs with new longer springs versus a spacer? If I put a spacer in there, how do I know what size tires will fit?
Thanks!
aggiedave98 is offline   Reply With Quote
Old 02-21-2004, 02:54 PM   #2
Prerunner1982
Prerunner1982's Avatar
they both will have the same effects on your tires. a small spacer, 3/4" will get you close to 3" of lift. to hell you say? due to the geometry of the front suspension it works like that. you could probably run 35"s as i run 32" on a stock 82 suspension.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
