Old 02-16-2004, 06:33 PM   #1
Larry68GMC
U-haul Tow Dolly
I just bought another truck and need to get it to my house. Will one of our trucks fit on one of those U-haul tow dollys? The guy I know with the trailer is outta town so I need to get it another way..Thanks..Larry
71 GMC LWB 350, Dart Pro1's 200/64cc,10.2:1
RPM AirGap, 224/234 @50 496/518 lift w/1.6 roller rockers, 2500 stall
'05 Dodge 2500 Crew Cab 4x4, 4 inch lift and 35's CTD
Larry68GMC is offline   Reply With Quote
Old 02-16-2004, 06:38 PM   #2
smokekiki
Mike
smokekiki's Avatar
When I checked last summer,the ones they had where to narrow.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 02-16-2004, 06:49 PM   #3
Davy
Davy's Avatar
They wouldn't let me put a Blazer on one last summer because of weight.
Width was OK though.
I told them to F. O. and used a buddy's trailer instead.
1970 Blazer CST
Looking for NOS items for my CST restoration.
Davy is offline   Reply With Quote
Old 02-16-2004, 07:04 PM   #4
kingparts
kingparts's Avatar
I used one to get my suburban home and it really didn't fit. The suburban was to wide. We traveled about three hours to find this out. We straped it down pretty tight. We checked it every ten minutes or so and I told myself then I would not try this again.
David
1970 Chevrolet Suburban
1967 Chevrolet C/10 Shortbed Stepside
kingparts is offline   Reply With Quote
Old 02-16-2004, 07:06 PM   #5
LGCC10
Junior Member
U-Haul trailer
I fit my C-10 6'stepside on a Uhaul trailer. Drove over a 100 miles with it and had no problems.
LGCC10 is offline   Reply With Quote
Old 02-16-2004, 07:12 PM   #6
68 Suburban
68 Suburban's Avatar
I think U Haul uses Demco Tow Dollies. They are great tow dollies, but I think U Haul buys the second largest one. That would be a tight fit. I have the largest one and our trucks fit fine.
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 02-16-2004, 07:13 PM   #7
68 Suburban
Old 02-16-2004, 08:11 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
How far you hauling it? Have you considered a tow bar? You can own one for 100 bucks from wall mart.
Old 02-16-2004, 08:42 PM   #9
rolson1039
Uhaul wont let you use the dolly to do the job bthey insist the dolly isnt wide enough. Ive hauled an 81 3/4 ton on a tow dolly without a problem. what you need to do is once you get it on the dolly ( and it is tight but it does fit) is to let the air out of the front tires so you can strap it down well then make sure you use the chains to hold the chassis in place. its not pretty but it works and by the way i towed about 300 miles that way
rolson1039 is offline   Reply With Quote
Old 02-16-2004, 11:06 PM   #10
Larry68GMC
Thanks guys..I'm only going about 30 Miles. Guess I will give it a shot. I will post some pics of it when I get her home. Its a 69 GMC 396/th400/AC/PS/PB/Posi. Lots of options, but needs the usual rust repair and a bedside. Thanks again guys...Larry
Old 02-16-2004, 11:13 PM   #11
useRc10
useRc10's Avatar
you might have to tell them you are pulling something smaller with something bigger or they will tell you no.
-'02 Chevy Avalanche, 5.3L, 4x4... needing a small lift and bigger tires
-'72 Chevy C-10(350, bored 60 over)dual flowmasters, 3 on the tree
-'85 K5 Blazer,305 NO MORE...350 is in,2" lift,33" Mickey Thompson Baja Claw Radials
-dads '70 burb (red, 5-7 drop, 350...)
www.geocities.com/userc10/truckhome.html
AIM: Auntjoedadda
useRc10 is offline   Reply With Quote
Old 02-16-2004, 11:30 PM   #12
Larry68GMC
Thats what I was thinking..Maybe like a 97 Escort or Neon 2 door. That should work..
Old 02-17-2004, 04:18 AM   #13
jimfulco
Brakes & steering work? Use a tow strap & a friend.
jimfulco is offline   Reply With Quote
Old 02-17-2004, 06:31 AM   #14
cojnit
Nothing clever
cojnit's Avatar
Use a tow strap and a friend
Not exactly legal in larger metropolitan areas. But swell in areas that matter, ask me how I know.
Got "the Midas Touch!"
cojnit is offline   Reply With Quote
Old 02-17-2004, 10:03 AM   #15
sparky69
I used a tow bar to tow a 71 from Kansas but it didn't track at all.
I found out later it was because I didn't had an engine in it for weight in the front. It would probably tracked good if there was more weight in the front.
Half way back to NC and a jack knife later I went too u-haul and got a dolly but I told them I was pulling an S-10. But I was using a crummy F%#D explorer anyway, too lite for c-10 they say.
It was a tight fit and add extra straps and had no problems at all going over the mountains.
sparky69 is offline   Reply With Quote
Old 02-17-2004, 10:58 AM   #16
Huck
Huck's Avatar
Tow dolly's
We pulled a 4x4 blazer from western KY to souther Indiana with my dolly, BUTT, the issue with most dolly's is that a 4x4 with ralley's is wider then a 2x4 truck in the front!!!!!!!!
If we towed it backwards, it might have worked a little better. We put on some stock wheels/tires and it fit between the fenders', but just fit with not much room to spare. We needed better tie down straps and once when breaking the blazer jumped forward of the dolly!!! Yikes!!
Dolly's are great for towing but are terrible for trying to back up--don't bother as it is a mess. I would tend to do it again if I had to but---now have better straps, will carry extra gas to allow for a smooth refuel at my leisure, and will chain the vehicle to the dolly as a precaution. I would also consider a tow hitch before the dolly. I have a flat bed that is capable but it would really need working brakes before loading 4,000+ lbs on it and towing it anywhere~~~.
Huck is offline   Reply With Quote
Old 02-17-2004, 11:50 PM   #17
Blue Beard
Blue Beard's Avatar
U-Haul wouldn't let me do my 66 International Box Van either.......
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 02-18-2004, 12:09 AM   #18
jamis
F.A.S.T. president
jamis's Avatar
dont tell them your using to tow anything.
Tell them you where hired to do a kids birthday party and you thought it would be a cool idea to pull the kids around in it....maybe take it on the highway and see who can hang on the longest......dont fall for the old "wait so we can check your credit" just run out before the cops get there:p
jamis is offline   Reply With Quote
Old 02-18-2004, 01:34 AM   #19
Larry68GMC
Just got her home and unloaded..Fit on the Uhaul dolly with about 2 inches on each side. No problems for the 30 mile trip. Will throw up a few pics tomorrow..
