02-16-2004, 11:33 PM | #1 |
c-clip elims
does anybody make a c-clip eliminator kit for 12 bolt truck rear ends?
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
02-16-2004, 11:47 PM | #2 |
5 day ban, learn to behave.
i think so. check it out- http://usgear.com/us_strange.htm
02-17-2004, 12:06 AM | #3 |
they sure don't provide very much product info
02-17-2004, 01:06 AM | #4 |
Dino burner
Moser Engineering also makes them for Impala/truck 12-bolts. Here's a link:
http://www.moserengineering.com/mose...ts.asp?CatID=2 Although you may have read magazine articles about how easy they are to install, or you may have heard of guys using a Sawz-all and did it in their driveway in an hour, I'd caution against that. The ends of your housing have to be cut off quite precisely, or you'll wear out the bearings very very quickly. Also, C-clip eliminator kits are notorious for leaking. DJS |
02-17-2004, 03:02 AM | #5 |
www.73-87chevytrucks.com
Swapping to rear disc will also "retain" your axles.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
02-17-2004, 12:49 PM | #6 | |
02-17-2004, 02:18 PM | #7 | |
02-17-2004, 02:35 PM | #8 |
yeller
On the subject of rear disc brakes, is there a kit you can buy somewhere?...one that doesn't cost an arm and a leg.
Or...are there any vehicles we can pull from that will bolt up with little to no modification?
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
02-17-2004, 03:23 PM | #9 |
91 SWB 383
pst sell a kit for 73-87 trucks.that where i bought mine from
96 2dr Tahoe protruning LS1 347/4L60L, PSI harness, body dropped, 4link, 6lug conv, narrowed rearend, Schoenfeld headers, 2600 stall, 317 heads milled .040, http://photobucket.com/albums/q169/k...ahoe prostreet |
02-17-2004, 05:23 PM | #10 |
Cadillac Seville has the same bolt pattern and has a provision to an e-brake. Most all aftermarket kits use these. You will need to make/modify the mounting bracket.
What to look for is a 79-85 Cadillac El Dorado, Olds Toronado or Seville.
