Old 02-16-2004, 11:59 PM   #1
low76swb
Headlight troubles
I was driving the other day and noticed my headlights werent on so i pushed in the switch and pulled it out and they turned back on and flickered out. I checked the fuses and even replaced the switch and tried replacing the lights themselves nothing Is there anything im overlooking, any ideas not being able to drive at night is getting old really fast
low76swb is offline   Reply With Quote
Old 02-17-2004, 01:00 AM   #2
Free88
Free88's Avatar
I can't really remember but if there is a dimmer switch on the floor I would change that. It's been a while since I have had a 76, and can't remember for sure if the switch is there or not. Change the dimmer switch and I am sure your problem will go away. That's my opinion.
1986 Silverado Short box fleet side. project
2005 VW Tiguan 4 Motion
1997 Blazer S10 4x4
1990 Chevy Silverado K1500 Extended long box
Free88 is offline   Reply With Quote
Old 02-17-2004, 01:31 AM   #3
BowTieMan
BowTieMan's Avatar
My uncle's were turning off on him. In a newer vehicle thought. It was a broken wire that wasn't making contact at all times. Sometimes they would touch and juice would go throught and other times it wouldn't. Maybe you have a loss wire.
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo
BowTieMan is offline   Reply With Quote
Old 02-17-2004, 01:42 AM   #4
apstguy
LED King
apstguy's Avatar
If you giggled the switch and replaced it and they flash, them maybe it is in the wiring harness that connects to the light switch. Disconnect it and make sure the wires are all in there snugly.
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 02-17-2004, 06:50 PM   #5
flip66
flip66's Avatar
check the hi low beam switch its a commen problem on chevy switch it and see if the lights come on. if its bad.
flip66 is offline   Reply With Quote
