Old 02-17-2004, 12:13 AM   #1
ocbaud
Garage Queen Material
a/c or no a/c???
i'm trying to decide if i should keep my a/c stuff.
will the compressor handle the engine revving to 6500? also, how much power does it take away having it on there(running and not running)
i kinda want it go just so its cleaner under there. and for the extra power
ocbaud is offline   Reply With Quote
Old 02-17-2004, 12:20 AM   #2
DCRANER
a/c or no a/c???
Most older vehicles a/c compressor will not last at 6500 RPM's. In the late 60's the muscle cars (GM) with the solid lifter engines and 6000+ RPM levels did not offer a/c as an option.
I took mine off of my 86 GMC to save space, etc. I will not use it since in the summer I would rather hear the exhaust sound. An older a/c compressor probably eats up about 15 HP in my opinion.
86 GMC SWB, DK. BLUE, ZZ430,TH400, 4.11'S, HEADMAN CERAMIC HEADERS, WELD BILLETS, BFG 275 / 60 / 15, 325 / 50 / 15 DRAG RADIALS, FIBERGLASS COWL HOOD, B&M SHIFTER. MSD, MARCH PULLEYS / ALT. / PWR. STEER PUMP, BECOOL RAD., BILLET GRILL & GRANT WHEEL.
DCRANER is offline   Reply With Quote
Old 02-17-2004, 12:24 AM   #3
1FaastC10
1FaastC10's Avatar
DCraner, i'm seeing 1 flaw in your logic. how often is Eric going to be racing his truck with the AC on? and how often is his 350 going to see 6500?
1FaastC10 is offline   Reply With Quote
Old 02-17-2004, 12:30 AM   #4
DCRANER
a/c or no a/c???
I assumed from his post that he will have a 6500+ RPM engine, and when "free wheeling" when a/c not on they do sometimes burn up the clutch mechinisim, etc., and at least throw the belt.
Just my opinion.
Thanks.
Old 02-17-2004, 12:31 AM   #5
ocbaud
how often is the vbelt gonna sqeak running at high?
with my old engine, i would floor it every chance i got
Old 02-17-2004, 12:32 AM   #6
ocbaud
i'll have the rev limiter set at 6500. the tranny i'm hoping will shift at around 6300-6400
Old 02-17-2004, 12:35 AM   #7
78SilveradoSWB
78SilveradoSWB's Avatar
I agree....If Eric plans to run quarter mile runs at each light, I'd be worried more about how long the engine will last. Keep the air and turn it off when you burn rubber.
Mitch
1978 Chevrolet Silverado C 10
454 BB, TH400
78SilveradoSWB is offline   Reply With Quote
Old 02-17-2004, 12:45 AM   #8
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
I have a v-belt for the alternator and it fly's off pretty easy. Normal driving no but getting in it fly's off. I need to get the wide pulley setup off a newer truck like DCRANER. Why they are so off center is beyond me as to why they are setup like that. I have seen plenty like mine that aren't lined up like that should be. Its a good 1/4-1/2 inch off.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 02-17-2004, 01:06 AM   #9
BaggedC10
Under construction!
BaggedC10's Avatar
Keep the A/C, especially if it's going to be a daily driver. Besides, the ladies like A/C!
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 02-17-2004, 10:31 AM   #10
gldevall
gldevall's Avatar
Ditch the AC.
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 02-17-2004, 11:09 AM   #11
bigblock73
yeller
bigblock73's Avatar
Ditch the A/C...more power and less weight. Also, easier to work on the engine with less crap in the way.
What do you think windows are for?
bigblock73 is offline   Reply With Quote
Old 02-17-2004, 11:50 AM   #12
Prerunner1982
Prerunner1982's Avatar
eric i dont have A/C but believe me when i am on my way to work with black pants and dark shirt on i regret it. and besides, think your girl would want to ride in it if she is going to sweat everywhere youll go? if you want to be the only one to ride in it... ditch the A/C... you are in the wrong state for no A/C and to be comfortable.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 02-17-2004, 12:46 PM   #13
low 84
low 84's Avatar
it aint a hotrod if it has a/c. gotta make some sacrifices for more power, better looks, less weight
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 02-17-2004, 02:08 PM   #14
swervin ervin
You get what you pay for
swervin ervin's Avatar
I ditched mine, and believe me, it's hot on 100 degree days. But, to me, a hotrod isn't supposed to have AC. My wife wont' ride in my truck in the summer, much less drive it. But, that's perfectly fine with me.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 02-17-2004, 02:13 PM   #15
Prerunner1982
i am lucky, my wife is a country girl and use to no A/C but when i have my 3 yr old in the truck i kinda feel bad.
Jon
Oklahoma Roll Call
Old 02-17-2004, 02:47 PM   #16
ocbaud
if i do remove it, what all goes about doing it? just unhook the compressor and the hoses? do i have to worry about the freon at all? what can i use to cap the line to the radiator and the a/c box on teh firewall?
Old 02-17-2004, 03:02 PM   #17
BaggedC10
Under construction!
BaggedC10's Avatar
If you remove it, do it the right way, and shave the firewall. Leaving the blower motor and etc. installed looks stupid, IMO. You've gone this far, what's stopping you?!
