Old 02-17-2004, 05:09 PM   #1
jared stewart
Silverado Stew
jared stewart's Avatar
Question Carb to TBI conversion
Anybody go from Carb to TBI by stripping all the TBI components off a running truck? If so, how much trouble was it and what are some of the things to watch for. I have the intake, TB, ECM, wiring harness, and all sensors. I can't seem to sell them, so I'm going to try to put them to use. It's going on a '81 with a 350, it came off an '87 with a 350.
- 1997 3/4 Ton Ext. Cab LB 4x4 6.5L Diesel
- 1979 3/4 Ton Longbed 4x4 "Farm Truck"
- 1984 1/2 Ton w/ '99 Vortec 350/700R4 2x4 FOR SALE
jared stewart is offline   Reply With Quote
Old 02-17-2004, 06:04 PM   #2
1FaastC10
1FaastC10's Avatar
im going to do the same thing with my L31 Vortec longblock. the only thing you have to watch out for with your pre-87 block/heads is the angle of the center two intake bolts, which can easily be elongated for use with the pre 86 heads.
1FaastC10 is offline   Reply With Quote
Old 02-17-2004, 06:44 PM   #3
swervin ervin
You get what you pay for
swervin ervin's Avatar
The intake bolt holes can be fixed, but this doesn't do anything for the mis alignment of the intake runners. Vortec heads are about 1/4" or so higher than regular heads. This will hurt performance a bunch.
Pretty shoddy way of doing something if you ask me. Buy the correct intake and do it right or leave it alone.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 02-17-2004, 06:52 PM   #4
jared stewart
Silverado Stew
So you're saying the '87 heads I took the intake off of are taller and the intake won't work good on my '81 heads?
Old 02-17-2004, 07:46 PM   #5
blazer boy
i'm about to do the same swap on my 85 2wd and was hoping to get some better mileage. what kind of mileage gains do you guys think i should see??? its a bone stock small block with a 700 and a 2:73 rear i'm getting 10 currently........
blazer boy is offline   Reply With Quote
Old 02-17-2004, 07:56 PM   #6
swervin ervin
No, I said Vortec heads. I was replying to Jeremy. 87 heads are not Vortec.
Old 02-17-2004, 11:00 PM   #7
1FaastC10
1FaastC10's Avatar
Mike, i'm well aware of that which is why im running a Vortec carb intake with an adapter and TBI from a 454.
