Junior Member
![]() Join Date: Feb 2004
I have a 72 Chevy and have tried a couple of different caps but if I fill the tank it leaks, Is there something I am Missing?
Bill Toothaker 72 K20 FSLB 63K FS:86 Mercedes 560SL 63 Ford F100 51 Willy's Jeep station wagon w/64 289 Studebaker 68 Honda SL90 1500 miles Chevy 6 cyl street rod 2011 Nissan Murano cross cabriolet Cabins for Rent Lake Winnipasaukee, NH |
No, U Da Man!
I had to replace the gasket on my original cap, it was dry rotted, that fixed my problem.
(sold ole blue 1972) ![]() 1997 Dodge 1500 5.9L 1996 Saturn SL2 1.9L 2002 Mitsubishi Montero 3.0L 2005 Ford Escape 3.0L 1967 Olds Vista Cruiser 330-320HP |
97' Tahoe 2dr/2wd
where did you get a gasket from?
67-72 Addict!
My new gas cap has always leaked.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
I have a brand spankin' new cap that leaks under hard right turns when full. I would like to put in one of those baffles that are in the necks on fillers in newer cars.
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
Surely there is a manufacture out there that has a billet cap with a chevy logo and a lock that is guaranteed not to leak....
My paint has streaks so much gas has leaked...ugh... Lets hear some solutions from the creative side of the board....my solutions so far have been shop rags in the bed...but that seems to be a fire hazard. Deland Im in for next week!
Glenn Cumming, Ga (68 C/10 Fleetside LWB 307 (64 C/10 Fleetside Shorty Custom 350, with 73 donor parts aplenty) (2001 Porsche Boxster S - 168 MPH of fun) (2005 Chevy Avalanche Z71 1500) |
Someone took my original Blue - matched the truck colour, gas cap and I had to buy an aftermarket one at a local store. It leaked and was difficult to put on and take off. I took out the original gasket and made one out of a piece of inner tube. It has been fine and has not leaked in several years.
I think you also need to be a bit careful not to totally fill with cold fuel from an underground tank on a warm day. The fuel will expand enough to leak out around the cap even when the truck is not moving. I wonder if you get enough expansion of the fuel to improve your miles per gallon calculations?
1968 Chevy - 292 with a powerglide |
1971 Chevy Cheyenne 383/350 LWB 2wd Built to use, and look good. ![]() |
Never Done?
![]() Join Date: May 2000
I had the same problem with mine. I picked up a cheap-o at AutoZone ('cause Jesse James told me to
Make sure you have the right year cap also. I believe the 67-70 cap is different, but I could be wrong. I don't have any catalogs in front of me to verify this. I had this problem once though.
Gas leaking from the cap on our old trucks (1955-72) is a common problem. If you looking for a good non-locking cap, I recommend Nappa. Ask for cap #703-1220, sells for about $10-$15.
Another thought, check the gas tank neck surface, where it seals up against the cap........... before you put the new one on. Look for nicks or dents, make sure it is flat & smooth. |
