Old 02-17-2004, 07:38 PM   #1
jaycom102002
factory a/c on a 350
I recently bought a 1970 GMC, it has factory a/c on the orig 396. I want to pull the 396 and put in a 350. Does anyone know if I can use the factory a/c without to many modifications?
jaycom102002 is offline   Reply With Quote
Old 02-17-2004, 07:44 PM   #2
rage'nrat638
rage'nrat638's Avatar
the 350 compressor mounts on the passenger side....
if thats where yours is at then all you need are the brackets...
by the way...your big block brackets will bring a good buck...
rage'nrat638 is offline   Reply With Quote
Old 02-17-2004, 07:46 PM   #3
rage'nrat638
ok here's my after market sanden comp. on my 350
Old 02-17-2004, 08:30 PM   #4
rage'nrat638
my compressor is mounted with allen grove brackets.....
that compressor sell's for about 200.00 new..
but i bought it used with the brackets for 110.00 shipped from smonty......GREAT GUY BY THE WAY......
two bolts and it off......
pull one bolt and the belt it lays back.....
no need to do anything to remove the valve cover
Old 02-17-2004, 10:27 PM   #5
Rod
I dont see much wrong with having a 396 for a spare either. BB ac brackets are sought after ... me included. I have a partial set of SB ones for trading partially if interested.
As for the swap... I think you may need only sb brackets, correct sb pullies for ac .... hmm I can help you there also.
Anyway... good luck on the swap. Rod
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 02-17-2004, 10:40 PM   #6
69 air cab
Say..Rage'n......you're cool pretty good?
69 air cab is offline   Reply With Quote
Old 02-18-2004, 12:28 AM   #7
rage'nrat638
WELL I AM GETTING READY...to charge this baby up...
just got it all together...going to change out two more o-rings
and they all will be replaced...the old one's were hard as rocks...
going with r134...thats what the compressor is rated for...
i hear that it's never going to be as good as r12 but it got to be better than sitting in a 100 degree truck
Old 02-18-2004, 10:01 AM   #8
Blazer1970
Blazer1970's Avatar
KEEP THE BIG BLOCK!
Blazer1970 is offline   Reply With Quote
Old 02-19-2004, 05:01 AM   #9
ZOOMY
BBC A/C brackets
Did all of the BBC's have the compressor mounted on the drivers side ? How about the BBC's for 67-72 ? .......Thanks.....Zoomy
ZOOMY is offline   Reply With Quote
Old 02-19-2004, 10:42 AM   #10
smokekiki
Mike
smokekiki's Avatar
My 71 has the big block with ac on passenger side.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
