i have a 97 K1500. took it to get an alignment and was told it still had the factory kit in it. this truck has 177,000 miles on it. i bought it at 165,000. While performing a brake job i took a look and looked to me that the cam blots were allready installed. they look like the same thing that i have seen on cars with struts( bolts with off set washers). was i lied to? need some help there is a diffrence of about $90 if they are already in there.
Thanks in Adv. Seth
97 ext cab 4x4 04 pontiac grand am 05 honda rancher AT (yellow) 71' C-10 swb sb400 th350 .040, 292 Mag comp cam, high rise Edelbrock w/750 duel feed Holley, Accel super coil and wires, B&M ratchet shifter |
Alignment cams!
Seth,
I sold suspension kits for newer chevys for a long time and I know the alignment issues pretty well. If there are offset washers attached to the upper control arm mounting bolts (at the frame mount of course), then cam-bolts have already been installed. The bolts have a D shaped cross section and the washers are shaped like an oval. Installing these cam-bolts is generally required when re-aligning the truck, and since it has 175K miles, I would assume it's been aligned before! Good luck, maybe try another shop (I've had good luck with sears and they're cheap, or try Fourwheel parts performance centers).
Nothing like building up a classic Chevy C-20 and turning it into a straight line king, and a canyon carvin' dream! That's right, it's all about the drive... -Jon Yaffe |
thanks i took my truck to another shop and they said that the bolts were there but i needed to knock out the stampings my self or pay them about $120 + alignment to do it.
