02-18-2004, 12:32 AM | #1 |
Driveshaft
I was wondering if anyone would know or has done this. Is it possible to convert the two piece driveshaft to a one piece? I have a 72 2 wheel drive long box. Thanks in advance.
02-18-2004, 12:40 AM | #2 |
i have one on my truck i have not had any probs yet i had it costom made i was blowing out carrier bearing out about 1 every 2-3 months i think that it cost me some where between 200$ to 350 something like that hope this helps
71 Chevy C/10 lwb 350 5 speed nv3500 3.73 rear end 2.5" Front Drop and 4" in the back Edelbrock perfomer rpm manifold Edelbrock 600 cfm carb Headmen headers |
02-18-2004, 12:42 AM | #3 |
Yes,thank you. That is exactly why I would like to convert to a one piece. Thinking about swapping to a much healthier motor and didn't want to change the hanger bearing everytime I decided to use it.
02-18-2004, 01:04 AM | #4 |
ran out of money
bad 71 chevy: did you have to grind out the crossmember the driveshaft goes though to make it work? plus is your truck lowered or anyting?
Sorry to kinda hijack this thread but i was also wondering the same thing. sorry again thanks Rat
Modify everything, leave nothing alone!~ |
02-18-2004, 01:06 AM | #5 |
its all about the +6 inches
You can run 12's on a stock 2 pc set up. If your C-bearing is going out often, then there is something else wrong.
02-18-2004, 01:07 AM | #6 |
it is not lowered but does have week springs but yes i did have to have a welding shop cut and then weld in a new pice kinda like a drive shaft loop i have had no probs with anthing but i might have some when i do get it lowered but thats while form now
02-18-2004, 01:21 AM | #7 |
ran out of money
bad 71 chevy: do you have any pics of your crossmember?
i am hoping to run low 12's maybe 11's when truck is done... or even faster if i can.... but NHRA might not allow the 2 piece shaft for running that quick... it doesnt specify in the rule book so i have to call the local guy for me Thanks Rat
02-18-2004, 01:24 AM | #8 |
i dont have a digi cam but i might be able to find a buddy of mine to take some pics i will post them hear if i can get some
02-18-2004, 08:24 AM | #9 |
71Rat, I know runnin high 12's with a slick, a stock 2 pc was fine.
02-18-2004, 10:05 AM | #10 |
71Rat:not a prob on the hijackin thing...good question I wish I had thought of it.
bad71: I would also like to see pics if you can get some Thanks |
02-18-2004, 11:59 AM | #11 |
I use to blow out carrier bearing all the time until I did my last install a differant way. I hung the carrier to the frame, left it loose to move, and did the rear u-joint first, then I tightened down the carrier. Seems that I was pulling the bearing back when I did the u-joint last and that would wear out the bearing donut.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
