Old 02-18-2004, 12:50 PM   #1
TwinTurbo
TwinTurbo's Avatar
brake rotors
One of my rotors is warped so I am looking for 2 new ones. Does anyone know a good source for rotors? Preferrably zinc washed ones.
Marck
TwinTurbo is offline   Reply With Quote
Old 02-18-2004, 01:10 PM   #2
Tom
driving is in my blood
Tom's Avatar
I put slotted/drilled rotors from a company called racing brake on all my vehicles when their stock rotors go south. Of course my company carries those rotors but there was a reason I choose to approach these guys at SEMA and get somthing going.
Old 02-18-2004, 01:35 PM   #3
TwinTurbo
TwinTurbo's Avatar
? your company? So you sell those puppies? If so, how much are they ?
Old 02-18-2004, 06:56 PM   #4
Tom
Tom's Avatar
I'll check and let you know. The company is v6performance.net INC. We usually do car stuff but we can get any rotors you want
Ill PM you with the price when I find out.
Old 02-18-2004, 07:00 PM   #5
TwinTurbo
TwinTurbo's Avatar
okie dokie
Old 02-25-2004, 01:57 PM   #6
TwinTurbo
TwinTurbo's Avatar
...still waiting.
Anyone else know a good source? I remember seeing some people here running them...n2trux, didn't you have zinc washed rotors?
Old 02-25-2004, 04:46 PM   #7
Mike76251
I asked this same question a while back asking about the Brembo's out there and got a funny answer from 1fastc10........."your truck is not a scma race car"
I know he meant it smart-as#ed but I thought it was real funny.
My truck warps any GM or Kragen's rotor within 2 years.
Last time I had a set shaved the guy said he had never seen any warped so bad.
I am not hard on the brakes at all so I don't know what to recommend..............you might try the Brembos from tires.com......it can't be worse than the GM jobs!
Mike76251 is offline   Reply With Quote
Old 02-25-2004, 04:51 PM   #8
TwinTurbo
TwinTurbo's Avatar
I have a really bad warped one too, dunno what caused it but it gives a really funky shimmy shake when braking. I want the zinc washed units because I don't drive the truck during the winter months. I fear part of the problem is that i drive my truck hard, even on the german autobahn. I've had it near the rev limit in 3rd gear (TH400) multiple times and some people like to swerve out in the left lane so hard braking is involved too. Brembo is an italian brand, do you have the part # ? Maybe they have them here in Europe which would save me a bundle on shipping & tax.
As far as being a race car, most of a brake system being race car only is not in the rotor but in the pads. The rotor size and design only affects the amount of heat (energy) it can store and how quickly it can get rid of it. Larger rotors can store more heat but if they can't vent it quickly enough you will get brake fade. The pads however, I run Wilwood (Raybestos) Polymatrix pads on my corvette and those are race only pads, they need to heat up before they work properly and they creaate a lot of brake dust and eat away rotors at an alarming rate. You can never have brakes that are too good, good brakes are not only powerful but can also be modulated properly.
Thanks for the link
Marck
Old 02-25-2004, 06:21 PM   #9
TwinTurbo
TwinTurbo's Avatar
I found 2 brembo rotors that fit, have to find out what the diff. is, the 1st one is a good deal cheaper so the 2nd the. #'s are 27016 and 27021. Then there are the ventilated or cross drilled sport rotors but i can't find them for our trucks...so that probably means there aren't any.
Old 02-25-2004, 07:21 PM   #10
Tom
Tom's Avatar
TPM dosen't make rotors for our trucks yet
Brembo rotors are going to be the same as any other. Just get the cheapest set you can find and use em. Even powerslots are re-badged GM rotors, and they usually use brembo blanks.
Old 02-25-2004, 07:32 PM   #11
1FaastC10
1FaastC10's Avatar
i remember that post clearly. your reasoning for wanting to know about Brembo rotors sounded as if you thought they were some sort of special performance rotors, which they are not. you stated your use for the truck, and if i remember correctly, that you were thinking of using slotted/drilled rotors. this is where the SCCA racing comment came in.
if you're not hard on brakes, your truck has a major mechanical failure then...
1FaastC10 is offline   Reply With Quote
Old 02-25-2004, 09:38 PM   #12
N2TRUX
Happy to be here
N2TRUX's Avatar
If you are only warping one rotor, your probably dealing with a sticking caliper. If the caliper doesn't release as it should, it going to cause excessive heat and warp the rotors.
Regardless of the pad/rotor combination you are running, if you are warping both rotors you should consider cryogenic treating your rotors.
If your not familiar with cryo-treating take a look here
Applied Rotor Technology I have used cryo-treated rotors and I can attest to it working "very" well. I am brutal on brakes. I run hard and stop harder. Most brake jobs don't last 18-20K. With Cryo-treating it has doubled, and even tripled the time between brake jobs....
I know he meant it smart-as#ed but I thought it was real funny. Jeremy? Smart @ss response? Get outta here:p
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-25-2004, 09:50 PM   #13
TwinTurbo
TwinTurbo's Avatar
I will try some new ones first before going all out on new rotors. Cryo treatment is out of the question, too expensive. I have cryo treated gears in my ZF6 speed and they were fricken expensive.
I don't have sticking calipers anymore but I did have one that was sticking a bit and that rotor is not warped, jsut a bit worn. The other side is the one that is messed up to the point that the guide pins are starting to wear flat spots.
ugh...I hate floating calipers, as service friendly as they may be. I'm almost tempted to buy some 4 piston calipers
Old 02-25-2004, 10:18 PM   #14
N2TRUX
Happy to be here
N2TRUX's Avatar
Cryo expensive? Hmm? Maybe over where you are, but not here. The onl part that was expensive about it was shipping. At the time I couldn't find anyone local that did brake parts. I shipped the rotors and pads from Texas to Cali and back....
Old 02-26-2004, 12:56 PM   #15
PHOENIX
Does anyone make a caliper and rotor kit for the front of out trucks?
Maybe a 2-piston system?
Does any wilwood kits work?
I would like to upgrade rotor and calipers next brake job if I can come up with the money and later down the road convert the rear to disc. Who has upgraded front rotors and calipers and what did you get and what did it cost? Thanks!
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 02-27-2004, 01:56 PM   #16
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
I love my powerslots. Crossdrilled.
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 02-27-2004, 02:16 PM   #17
TwinTurbo
TwinTurbo's Avatar
SSBC has a 2 piston caliper
Old 02-27-2004, 02:24 PM   #18
apstguy
LED King
apstguy's Avatar
I think you have to use 17" rims when using SSBC caliper though.
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 02-27-2004, 04:17 PM   #19
TwinTurbo
TwinTurbo's Avatar
why? that depends on the rotor diameter
http://www.stainlesssteelbrakes.com/products/superTwin/
doesn't mention anything there. If I would do it I'd isntall some new spindles and convert to 4 piston brakes. I've got some Wilwood Integra 4s, Superlites and IR-GTs lying around so maybe one day....
Old 02-27-2004, 07:23 PM   #20
PHOENIX
SSBC (Stainless Steel Brake Corp)
Vehicle: Chevy 1/2ton Truck (2wd) - 1983
Part Number A185-M
Retail Price $465.00
Minimum Wheel Size 15"
Caliper Specs:
Name SuperTwin HD
Number of Pistons 2
Piston Size 43mm
Constructed From Aluminum
Standard Finish Clear Anodized
Optional Finishes Polished or Powder Coated
FEATURES
All hardware included.
Calipers come with clear anodized finish. Optional polishing or powder-coating available.
Direct bolt-on replacement to O.E. single piston caliper.
For O.E. disc brake vehicles with single piston caliper.
Includes Force 10 SuperTwin HD 2-Piston aluminum calipers.
Includes high performance pads.
________________________________________________
Is this a set, two calipers?
When they say designed for heavy duty braking applications, do they mean your vehicle came with heavy duty brakes or you plan to do heavy braking? The kit above is for heavy duty braking.
Old 02-28-2004, 06:54 AM   #21
apstguy
LED King
apstguy's Avatar
My bad. Must have been a brake kit I was looking at from another company...
Tyler
2016 Chevy Spark EV
Gone: 2008 VW R32
Old 02-28-2004, 02:56 PM   #22
76bonanza
76bonanza's Avatar
Anyone use there rotors and pads? SsBC that is
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
