its smokin
when i am hit the gas hard on my 68swb.it will smoke for mile or so.smells like oil burning.it sometimes comes up in the cab.i also notice the oil pressure pegs on high when it does this.it also sits about 3/4's on the gauge during normal driving.i dont know much about this motor.it was suppossly rebuilt before i got it.i just started driving it.it feels real strong.350 4 barrel.i was thinking maybe someone installed a high pressure oil pump and it was spilling out of the dip stick on to the headers.any thoughts ideas?thanks
springfield illinois 2003 custom (harley)built from scratch 68 swb |
Formerly yellow72custom
Is it coming from the tailpipe?
It could be a oil leak spilling oil on to the exhaust and burning. Had this happen with my truck, valve cover gasket was shot and it would spew oil onto the headers when i floored it and the oil pressure went up. Get out and check the engine bay, along with the underside of the truck and you will see if it is leakign any oil.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
tires?
70 chev c10 swb fleet 72 grill, sb 400, 2/4 drop. 68 chev c10 swb fleet Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C Classic GM Truck Club of Washington . |
my gas saver
should be a leak coming out and burning off
crazy4chevs,i wish it was only tires.oh i mean tire
My other Love
hmm maybe a crankcase pressure problem, getting too much back pressure into the crankcase during acceleration causing oil to be forced into the cylinders, id check you pcv
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
hmmm..i never thought of that.what else may cause crankcase pressure to soar
if the engine is rebuilt have the rings had time to seat well?
PR Too many projects, not enough time! 72SWB 350/350TH, 3500stall,525 lift cam 3:73 posi. Sold! 69LWB Flatbed 350/Super T-10, ported/polished 481 heads, 480 lift cam. 78SWB 468/400TH, ported/polished Alum. heads, 3:42 posi, 3000 stall on 17x8 and 18x9.5's 77 Jeep CJ-5 304V8 fiberglass body on 36" Ground Hawgs |
