Old 02-18-2004, 06:43 PM   #1
davidh
davidh's Avatar
Do 73-87 lower and upper arms fit 67=72?
It seems I heard you can swap out 73-87 lower and upper a arms directly into the 67-72 , then using the spindle from the73-87 thus having the disc brakes. I guess you would also use the 73-87tie rods as well. Let me know if I'm right and what else is needed.
Even the nicest dodge-chrysler is only 2years away from being parked outside of Section 8 housing.
davidh is offline   Reply With Quote
Old 02-18-2004, 06:53 PM   #2
crazy4chevs
crazy4chevs's Avatar
you are correct, but i think you need a special adapter to connect the 67-72inner tierod to the 73up outter ones.
70 chev c10 swb fleet
72 grill, sb 400, 2/4 drop.
68 chev c10 swb fleet
Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C
Classic GM Truck Club of Washington
crazy4chevs is offline   Reply With Quote
Old 02-18-2004, 07:42 PM   #3
davidh
davidh's Avatar
Well if you are changing power steering as well from the 73-87 couldn't you just use the whole bar from pitman arm to idler arm from the 73-87 donor?
Old 02-18-2004, 07:53 PM   #4
crazy4chevs
as long as you change the centerlink and idler arm i dont see why not.
