Old 02-18-2004, 09:29 PM   #1
90blzr
FS: 4L80E JET PERFORMANCE Tranny....BRAND NEW
Selling for a friend. This thing is still strapped to the pallet it came on, never installed, brand new. This is a DEAL!!!
This was going in a 83 Chevy K30, but the project was terminated. Should also fit Blazers, suburbans, etc of same vintage.
Selling my Jet Prepped 4L80E Tranny, its brand new, still on the pallet. I paid $3,600, will sell for $2,500. obo
4L80-E Transmission 4WD
The JET 4L80-E is the ultimate in overdrive transmissions. The 4L80-E has the same strength as a T-400, but also features a 4th gear overdrive and lockup torque converter. Capable of handling up to 700 ft/lbs or torque and 24,000 GVW capacity! Available as a replacement for 91-up GM 2500 and 3500 trucks, or for use in conversions using JET's TransConversion Kit. The 4L80-E is suited for big-block trucks, pro-street machines, motorhomes and extreme towing applications.
34 element sprag for big-block holding power
Positive, responsive shifting
Available with stick/automatic feature for manual hold in lower gear ranges
Heavy duty clutches and band
Modified valve body
Goto www.jetchip.com
90blzr is offline   Reply With Quote
Old 02-18-2004, 11:53 PM   #2
jamesjones
Freakin Awesome!
jamesjones's Avatar
Does it come with the transmission controller?
jamesjones is offline   Reply With Quote
Old 02-19-2004, 11:42 AM   #3
90blzr
controller....
No it does not. I believe that is about $450.....but any way you look at it, you are still saving over $1000. If I had the $$, I'd buy to go in place of the one in my 91 Crew Cab 4x4.
