Old 02-18-2004, 10:39 PM   #1
337
Cheyenne super 20 -donor questions
I found a 72 Cheyenne Super 20 doner for the power steering box, brake booster w/ brake rod, bracket, master cylinder, and proportioning valve.
Will this work for my 70 C10 - 307 3speed?
I've searched and read that the brakebooster should bolt up.
I've also read the power steering will bolt up if my frame is indented.
Do I need the steering rod connected to the power gear box(the rod that connects to the steering column)?
Will i need to use a 72 pitman arm when installed?
thanks
337 is offline   Reply With Quote
Old 02-18-2004, 11:01 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
I've searched and read that the brakebooster should bolt up. YES
I've also read the power steering will bolt up if my frame is indented. YES
Do I need the steering rod connected to the power gear box(the rod that connects to the steering column)? NO
Will i need to use a 72 pitman arm when installed? YOU SHOULD INSTALL THE PS BOX AND IT'S PITMAN ARM, NO NEED TO USE THE ONE OFF YOUR MANUAL BOX.
Don't forget the PS Pump/brackets, as well as the lower crank pulleys (assuming your donor is a small block truck)
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 02-18-2004, 11:12 PM   #3
337
SWEET!!!
Thanks for the info.
It had a 350.
The motor is gone but the pump, bracket and pulleys will be the easy thing to find.
Thanks again.
Old 02-18-2004, 11:14 PM   #4
337
oh yeah i also got the instrument panel with the gauges from the same truck.
Do you know if it will need mods?
I got idiot lights.
I took the oil sender assembly which attachs to the instr panel.
Old 02-19-2004, 12:56 AM   #5
Hooter
My other Love
Hooter's Avatar
yes you need to change the whole wiring harness out, the idiot light dash is wired completley different then the guages, so its best to get the wiring harness out of the other truck, or else you will fry your electrical system
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 02-19-2004, 01:25 AM   #6
Rod
Paul has a faq about swapping idiot light clusters to full guage. http://gmcpauls.com/Tech%20Tips1.htm
But you could always swap the inside and outside harness too.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 02-19-2004, 02:17 AM   #7
337
Thanks i'll try to modify mine.
if it doesn't work then i'll go get the harness.
