[Pic] What is this little electrical connector thingy?
I've always wondered...can I take this off? If I could take this off, then I could REALLY clean up my firewall...
You get what you pay for
![]() Join Date: Dec 1999
It's a junction block. 12 volts comes and and branches off to different areas. You got to have one somewhere. You could move it and re route everything I guess.
Mike 1985 Chevy C-10 |
Under construction!
That red wire has been spliced and diced a few times.
2001 Silverado bagged on 22's. *Sold* |
#4 | |
5-7 dropped 87 CC Dually
PLEASE! Unhook your battery before touching that Thingy!
I rather be in my 77 Sanger Picklefork Jet Hydro! |
I believe that may also be a fusible link. The small piece of metal in between the 2 posts acts like a fuse and melts when too much current is pulled. I had the same thing on a car I used to drive.
It's not a fusible link, only an isolator. The fusible links are in the wiring.
One of the wires is your high speed feed for the HVAC blower. One goes down into the loom with a fusible link and depending on year there is a second that goes down into the loom. My 75 doesn't have it but my 79 and 88 does. I thing that it's for power tail gate window. My 75 didn't have that and trucks wouldn't have it so probably not there.
Stupid idiot in 1989 that installed the wiring for the trailer brakes jacked that up on my 88 sub. I have paperwork from both previous owners where the deal had a complaint of intermitant failure of the blower to function on high. I found that the trailer knuckle head left the nut loose on the left terminal and the wire would loose contact. It had been that way 12 years and reported complaint EVERY time it went to the dealer when under warranty. Anyway you could route that high speed blower feed down to the starter and tag power there. I would put a fusable link for about 30 amps on it. Once that is out of the way if you only have a single wire left like my 75 does then you could tape it off and pull it into the loom behind the engine to make it disapear.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
| Bookmarks |
