Old 02-19-2004, 01:28 AM   #1
aggiedave98
what to replace while doing front lift?
I'm going to put in a 3" suspension lift into my '89 suburban 1/2 ton 2wd. What should I replace while I'm in there?
inner tie rod?
outer tie rod?
ball joint?
I definitely need to replace the control arm bushings. It seems like there are polyurathene (sp) ones and even ones w/ metal sleeves on them ranging from $30-$80. Which kind are the best? Is there much of a difference?
aggiedave98 is offline   Reply With Quote
Old 02-19-2004, 11:43 AM   #2
Seon
Seon's Avatar
Do it all and have the front wheels aligned. Then you''re Burb will be good for another 20 years .
Seon is offline   Reply With Quote
Old 02-20-2004, 03:30 AM   #3
aggiedave98
Ok, but what about things like the idler arm etc. Should I replace everything??
