COMING SOON...
contol arm clearance
Could someone get a quick measure on the distance of your lower control arm to the ground, if your truck is lowered 4.5"? Mine seems lower than usual.
Posted this on Message Board but got no response. |
COMING SOON...
Still nobody?
I have what is a 3.5 drop but I only have the motor and cab on the frame. Would you still want the meaurement ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
COMING SOON...
Sure, thanks.
Low & Slow
with a 4" drop, 2.5 spindles and 1.5 springs the lowest point of the arms (spring cup) looks to be maybe 4.5 inches from the ground. Hope this helps.
70' C-10 LWB Fleetside 4.5/6 drop ![]() |
