I'm lowering the front of my '72 Suburban with 2" drop springs. I believe throws off the camber. If this is correct, can the situation be fixed with shims or should I use the offset upper control arm shafts? The pic on the top is the offset one. Thanks.
Is it a C-20 3/4 ton?
Rest in Peace Ed. Thanks for all the good times. |
It's a 1/2 ton, but it has "2nd design" front end parts which are the same as 3/4 ton front end parts. See my post about it. http://67-72chevytrucks.com/vboard/s...hreadid=90055.
I would get the 1/2 ton uppers and correct concave shims on a 2" drop coil, I believe the offset is for 3" and lower coils but i could be wrong. Whats the company you bought the coils from say to use?
