02-19-2004, 02:57 PM | #1 |
getting vacuum source for brake booster
where do you get the vacuum source for a brake booster?.....didnt know if it was on the backside of the intake or the back of the carb.....on my new edelbrock it has a plug in the back that has something to do with vacuum,and on the intake i have a T fitting with one line going to the transmission i think and the other line going to the vacuum cannister for the A/C....where do i need to be going to get vacuum for the booster?
he who dies with the most toys wins... |
02-19-2004, 03:14 PM | #2 |
Formerly yellow72custom
You can get it from the plug at the back of the Edelbrock carb, or from the port on the intake directly behind the carb. Either source should work fine, although it woudl proably be easier to tie into the threaded port on the back of the carb.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
02-19-2004, 03:17 PM | #3 |
ok,thanks....im trying to remember if my edelbrock came with a fitting,but if i cant find it where would i get one?....at any parts store?
02-19-2004, 03:37 PM | #4 | |
Howzit?!?
My Edelbrock came with some fittings but not all that I needed, and no plugs. Good Luck. J
Jason Hawaiian-J 70 Longbed, 307, Edelbrock Carb 1404, Edelbrock Intake 2101, Dual Roller Timing chain and gears, 214/214 cam, Comp Roller Rockers, dual Flowmasters. 1999 Chevy Tahoe 2004 Mini Cooper S 71 BMW 2002 - Sold |
02-19-2004, 08:16 PM | #5 |
I have mine from the intake, but I have problems with my power brakes not being power at idle because of my cam. Is there any fix for this? Would it be an easy conversion back to manual?
02-19-2004, 09:16 PM | #6 |
72step, you can buy a vaccum cannister that holds excess vaccum until you need to stop. Summit and Jeg's carry them.
02-19-2004, 10:11 PM | #7 |
i have another question about my booster...there is a rod that is in the center of the front of the booster...it goes into the back of the mastercylinder.....mine has come out...will this hurt the way the booster operates?....the guy at the aprts store said it probably wonk work right...thats the way i bought it,with that middle rod out of it...does anybody know anything about this?
