Old 02-19-2004, 03:55 PM   #1
72superBB
72superBB's Avatar
Cranks & Cranks.......& Cranks, but won't start!
What do I do?
Has gas.
Was running when I parked it 2 months ago.
Has a new fuel filter,
New distribiter cap & rotor (whetever it is called)(HEI)
Gas is getting to the carb
No wires are unhooked anywhere that I can tell.
What do I do?
I posted this in the engine side, but I am in kind of a hurry.
Life is full of choices and a Chevy is the best choice.
1990 Chevy SWB
72superBB is offline   Reply With Quote
Old 02-19-2004, 03:59 PM   #2
Southpa
Southpa's Avatar
Process of elimination. Pull the spark plugs and see what condition they are in. Got a Haynes or Chilton manual? They have fairly good troubleshooting guides.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 02-19-2004, 04:01 PM   #3
CPNE
Resident Curmudgeon
CPNE's Avatar
Make sure you have 12V to HEI and then pull spark plug, ground it and see if you get a spark when cranking. If 12v to hEI and no spark, you need to investigate the HEI and module
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 02-19-2004, 04:01 PM   #4
72superBB
72superBB's Avatar
Spark plugs are brand new, gapped at .045.
I have a manual, but I thought maybe someone had a quicker way of trouble shooting this.
Thanks, I'll start reading.
Ron
1990 Chevy SWB
Old 02-19-2004, 04:14 PM   #5
Inthuwind
Straight jacket required
Inthuwind's Avatar
make sure your firing order is correct and plug wires are in order on your distibutor. Is it vacuum advance distibutor? Also, check out the "stator" and "resistor" in distributor. Hope this helps~~
1968 C10 Short Stepper
350/350 A/C P/S P/B Front disc
3/5 static/ 12bolt rear 3:73
1979 Pontiac Trans Am
10th Anniversary/455/4spd
2011 H-D Street Glide - CAMMED n lowered
Dad always said,"Son, if you can't be good...be good at it."
Inthuwind is offline   Reply With Quote
Old 02-19-2004, 04:17 PM   #6
67chevy2wd
67chevy2wd's Avatar
just a thought but if it was me i would check the power wire to the distributer and see if it was chewed off by and mice.
67chevy2wd is offline   Reply With Quote
Old 02-19-2004, 04:19 PM   #7
bobbys1967
I agree with CPNE. If there is 12V to the HEI and no spark, then it is your coil, module, or the pickup coil. Some auto parts stores have the ability to test the module and the coil. As for the pickup coil, It should say in your manual how to test it with an ohm meter. None of these parts are very expensive. Hope this helps
Bobby
1970 K10
bobbys1967 is offline   Reply With Quote
Old 02-19-2004, 04:20 PM   #8
Inthuwind
Inthuwind's Avatar
I reread your description...make sure your wires on the cap are in firing order with your vacuum advance. (if the vacuum advace points clockwise,put plug firing order clockwise)(counterclockwise,put plug firing order counterclockwise) __unless you knew that already
Old 02-19-2004, 04:25 PM   #9
bobbys1967
I've never seen the firing order on any chevrolet motor differ from clockwise.
1970 K10
Old 02-19-2004, 04:34 PM   #10
Inthuwind
Inthuwind's Avatar
I was told that Pontiac and Chevy were the same--but the 400 Pontiac I had was counterclockwise~~sorry.
Old 02-19-2004, 06:10 PM   #11
MJN
MJN's Avatar
I would check the coil connections and try a different module inside the distributor. I had this problem before, P.O. converted to HEI but left the original power wire to the distributor there and kept burning out modules, changed the wire with one from a '76 truck and haven't had a problem since.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 02-19-2004, 07:31 PM   #12
superfly68
superfly68's Avatar
i'd start with oulling #1 plug wire and seeing if you have spark. if you have spark and gas. only other option is no air...check to see if the choke is closed. good luck. kep us informed!
no longer have a ride, but still a fan!
superfly68 is offline   Reply With Quote
Old 02-19-2004, 08:37 PM   #13
72superBB
72superBB's Avatar
Replaced the module (thing that sits on top of the dist. under the dust cap), and still no luck.
I parked it in december running. It has had a tranny leak is why I have not driven it. I have done nothing to it except put in a tach (which I made sure i hooked it up right to the distributor as well.
WHat now?
Thanks for the help guys!
Ron
1990 Chevy SWB
Old 02-19-2004, 08:40 PM   #14
superfly68
superfly68's Avatar
what carb are you running? manual choke? i had mine close somehow and the truck wouldn't run. are you getting spark?
Old 02-19-2004, 08:47 PM   #15
72superBB
72superBB's Avatar
Holley 750 , manual choke
1990 Chevy SWB
Old 02-19-2004, 08:48 PM   #16
oldsub86
Go back to basics. Check for spark at the plugs. If you have spark, then check to see if there is fuel at the carb. Open the choke and look down the carb and pull on the accelerator linkage to see if fuel sprays into the carb. If you have fuel and spark it should at least try to fire up.
If it was running when you parked it and the only thing you have done is add a tach then I would also check out the wiring for that especially where it connects to the distributor. Did you dislodge something or have you got the wires on in the right spot.
This is very basic and it has to be a simple answer.
1968 Chevy - 292 with a powerglide
oldsub86 is offline   Reply With Quote
Old 02-19-2004, 08:55 PM   #17
72superBB
72superBB's Avatar
I cannot seem to get a spark from either on of the spark plug wires at the front of the motor. I have put a screwdriver into the plug and held it close to the wheel well and nothing.
WHat now or what is the next thing I check? Do I run a wire directly from the battery to the one side of the dist where it is currently connected?
1990 Chevy SWB
Old 02-19-2004, 09:00 PM   #18
superfly68
superfly68's Avatar
got to be the wiring.... check and double check that all connections are clean and tight.
Old 02-19-2004, 09:02 PM   #19
72superBB
72superBB's Avatar
There is fuel, because I have seen the spray. Wiring is correct because it says BAT and TACH on the top of the dist. and that is how I hooked it up.
Is the wire that goes into the BAT side hot all the time? If it is, then I can check to see if there is power to that.
Ron
1990 Chevy SWB
Old 02-19-2004, 09:08 PM   #20
72superBB
72superBB's Avatar
Ok, that wire is hot when the key is turned on. So I know there is power getting the that point.
1990 Chevy SWB
Old 02-19-2004, 09:34 PM   #21
jef5150
Inline 69
jef5150's Avatar
i dont know much about h.e.i, but dont you need 12v in the" crank position" to get it started,and 12v in the "on" position to keep it running? i might be way off but just my .02 jeff
jef5150 is offline   Reply With Quote
Old 02-19-2004, 09:38 PM   #22
Inthuwind
Inthuwind's Avatar
my dad had the same problem with his monte carlo---came to be the stator under the rotor---also check condensor
Old 02-19-2004, 10:18 PM   #23
Old Dave
Is a bullfrog waterproof?
Old Dave's Avatar
It possibly could be the pickup coil (under the module) that triggers the distributor module. You can check it with an ohmeter by pulling the 2 prong plug off the left side of the module and checking the resistance on the yellow and green wires. It should read between 140-160 ohms. I am betting it's the module. Like somebody above said, a lot of auto parts stores have the capability to check these to see if they are bad.
"It is better to remain silent and be thought a fool, than to open one's mouth and remove all doubt."
Ben Franklin
1970 Chevy shortbed
2002 Harley Custom Chopper (Long sucker)
1998 K2500 5.7L 5-speed Longbed
1st two are My son's toys...they just live in my garage!
1997 GMC K1500 Suburban
1993 S-10 Blazer 4D (youngest son's daily driver)
2000 Dodge Ram 4WD Ext. Cab (5.9L)
Wife is a late year 1951
Old Dave is offline   Reply With Quote
Old 02-20-2004, 12:01 AM   #24
rage'nrat638
rage'nrat638's Avatar
TRY STARTING FLUID
rage'nrat638 is offline   Reply With Quote
Old 02-20-2004, 01:02 AM   #25
FirstGen
Just Don't Stop!
FirstGen's Avatar
I agree with Old Dave!
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
