02-19-2004, 08:54 PM | #1 |
WTB - Manual trans linkage
Planning on putting a Tremec in my swb cheyenne (2wd) project. The truck was originally a 3 on the tree years ago before I swapped in a TH350 with a tilt column. I got rid of all the original linkage and (if I remember) removed the frame mounted Zbar mount.......I think that's what is was! I kept the clutch pedal and just pushed it against the firewall under the carpet.
........so years later (if I'd only known) I'm considering putting a manual back in to increase the "fun" factor of driving the truck. Don't know what linkages will work.....4 speed (2wd or 4wd), 3 speed, big block or small block (mine's a small block) etc..... I'm also concerned as to whether or not my headers (Doug Thorley) will clear the linkage. Since the tremec I'm looking at will bolt up to any bell housing that accepted a muncie, I'm looking for whatever linkage will work with that setup, including the piece I ripped off the frame. Thanks for any input.
72 swb Cheyenne "nut & bolt" frame off (in process) Blown 383 |
02-19-2004, 10:37 PM | #2 |
I'll check my stash and see what i got!
Things happen for a reason! |
02-20-2004, 12:59 AM | #3 |
if big orange cant help you let me no i have some if i can find it thanks bill
i have 67/72 chevy truck parts f/s. |
02-20-2004, 01:52 AM | #4 |
Thanks.......I do appreciate.
