Old 02-20-2004, 12:10 AM   #1
ocbaud
Garage Queen Material
do i need to shim my starter?
thats as far as it goes in
ocbaud is offline   Reply With Quote
Old 02-20-2004, 12:24 AM   #2
Chevy67Tk
Chevy67Tk's Avatar
Can’t tell from that angle
You need to pull the drive gear out towards the read of the engine and check the gap between the top of one drive tooth to the valley between to of the flex plate teeth
Chevy67Tk is offline   Reply With Quote
Old 02-20-2004, 06:41 AM   #3
TIMSPEED
TIMSPEED's Avatar
Eric, the best way to check, is to use an 1/8th" Allen wrench, and put it between the starter shaft and the teeth on the flexplate, if there's anymore space than that Allen Wrench, shim it till it's exactly 1/8th".
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 02-20-2004, 02:12 PM   #4
BaggedC10
Under construction!
BaggedC10's Avatar
Install the starter w/o shims first. If you start the truck and it ziiings, you need to add shims. My truck and El Camino didn't need shims.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 02-20-2004, 04:10 PM   #5
76HighSierra
DAMN, I love Big Blocks!
76HighSierra's Avatar
Timspeed, I think that procedure only applies with OEM size armature shafts. The shaft on his aftermarket, hi-torque starter looks much larger in diameter. That alone, will throw his measurment way off.
Marc Bona
Hobbs, New Mexico
1976 1/2 ton GMC High Sierra.
454 c.i.d./ TH400. *Soon to get a mild warming over.*
3.40 rear.
76HighSierra is offline   Reply With Quote
Old 02-20-2004, 06:59 PM   #6
ocbaud
i have no shims on it now. i was just wondering about it. the shaft on the starter looks very very close to the teeth on the flexplate
Old 02-21-2004, 03:22 AM   #7
ocbaud
i cant turn the starter gear by hand without it hitting the flexplate. how can i fix this?
Old 02-21-2004, 11:23 AM   #8
Chevy67Tk
Chevy67Tk's Avatar
Add 1 shim and re-check.
Now is the time to do this while the engine is still on the stand
