question about a used booster
i bought a used booster and was told from a parts store guy it may not be useable....on the booster there is a rod that comes out of the front and into the back of the MC....the rod on the booster i have has come off...will that affect the operation of the booster?....the parts store guy said it probably wont wok right now that the rod has come out,but i dont know
he who dies with the most toys wins... |
Designated A-hole!
Mine falls out every time I pull the master cylinder out. It still works fine. Sounds like he is trying to sell you a new booster.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Try spinnin 4 rear tars
He is just trying to make a sale... Just stick the actuator rod back in the booster and bolt it up. It will work unless there is something else wrong with the booster.
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
ok,thanks alot....so that little rubber washer looking thing is ok to be loose too?....is it suppose to be glued on or something?....you know,the one the rod slides through?....and also,on that rubber washer looking thing,one side is rubber and one side is metal,which side goes out...the rubber side?
Designated A-hole!
If I remember correctly the metal side goes out. If I am wrong, then turn it around.
Progress = 0%
Mike, I marked an "X" on the rod and washer so you'd know which way it went. That is the way it was when I found it in the box so I'm assuming that is the correct way. Can anyone verify this?
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
oh,ok....thanks i just saw that
its all about the +6 inches
You are talking about the rod that is inside the booster that actually pushes on the master cylinder piston? If so, yes it does come out, and it is adjustable. Look at the ends, one side has the rounded end that unscrews. Place that side towards the master cylinder.
how do you know how far to adjust it?....or when to adjust it?
