Junior Member
Air Bag port size?
What size port should be used on a 67 shortbed 3/8 or 1/2 inch Don't want to hop just want to raise and lower it.
Thanks Pete |
Rockers1/2"off the ground
3/8 should be fine if ya don't want to get to crazy.
1962 fleetside: bodydropped,shaved,bagged,custom 64 suspension,clear taillights,custom aluminum parts,rollin on 100 spoke player wire wheels. http://www.finelinedesignz.ca |
Try spinnin 4 rear tars
Half comment, half question
wouldn't the .5" port cause the truck to react faster to inputs of controls?! The bigger the port, the more volume of air, the quicker the truck raises and lowers.
Personally I would go with the smaller one, I'm not in to hopping, but being able to get just the right ride height would put a big ![]()
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
you might consider going 1/2" on your intake valves and 3/8" on your dump valves. that way you could get up fast but wouldnt tear anything up on the way down..or should i say that you would have better control over it on the way down.
1972 chevy long bed. Currently under construction!! Bagged, 383/700r4. |
#5 | |
Trucker.
