Old 02-21-2004, 09:42 AM   #1
tomsC10R
tomsC10R's Avatar
Dreaded rivet removal Please help me
I did a search and found some info. but... I just wanted to double check. What is the best way to remove these things?
Do you have to grind the heads off first? What have you guys used to do this? All I have is a cheap a$$ angle grinder... Do you think that'll take care of it? Would I then be able to punch out the rivet or will I need to drill it out?
Thanks.
Tom
1968 C10 LWB. 402 BB, Holley MPI, 700R4. 4wheel Hydroboost Disk Brakes.
tomsC10R is offline   Reply With Quote
Old 02-21-2004, 10:09 AM   #2
CPNEJR
CPNEJR's Avatar
Yes I think that would do it If you have a hole punch that would difidently work
(Only) Member of the CPNE Fan Club Aint that the truth
67 C-10 350 with 3-speed tranny and 308 gears swb step
82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine)
72 Chevy K20 Suburban (future project)
70 Chevy K20 now 68 GMC K2500
2003 Chevy 2500hd ccsb 4X4 (daily driver)
CPNEJR is offline   Reply With Quote
Old 02-21-2004, 11:08 AM   #3
MrGoodpliers
MrGoodpliers's Avatar
Are you talking about frame rivets? If so, what i do is grind a little off the head, just enough to get it flat. Then centerpunch, then use avery good drill bit just a bit smaller than the hole the rivet is in (you'll have to guess, since you can't see). Drill just enough to get it through the frame, then punch it out. The head on the top just pops off, and you don't have grinding marks oun the frame.
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC...
MrGoodpliers is offline   Reply With Quote
Old 02-21-2004, 12:15 PM   #4
John Fabris
TOTY 2006
John Fabris's Avatar
I have removed some by drilling the center out, then used a metal chisel and hammer to knock the head off.
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 02-21-2004, 12:51 PM   #5
JimKshortstep4x4
Talking
I usually use an air chisel, but I have taken a lot of rivets off with a big hammer and chisel.
Jim
Old 02-21-2004, 01:26 PM   #6
ts71281
I got smart and went out and bought an air chisel. One of the best tools I own. I use the flat wide chisel to remove the head of the rivet and then once I'm done with that I use my big round punch attachment and just push the rivet through the hole. Takes only a minute or two per rivet. Just remember to wear safety glasses, a lot of crud will come loose and fall into your eyes with that quick vibrating action on the frame. Even on the cleanest of trucks!
ts71281 is offline   Reply With Quote
Old 02-21-2004, 01:32 PM   #7
gr8scott51
gr8scott51's Avatar
A cheap a55 grinder will work (my $14 grinder did). Grinding wheel marks can be painted, but if you're careful, you won't hit the frame. Sometimes when you punch them out, the frame parts will shift and bind a little, just be patient.
good luck, scott
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 02-21-2004, 02:17 PM   #8
jaycom102002
I am knocking rivets out right now too. My question is what size and grade of bolts should I use to replace the rivets?
jaycom102002 is offline   Reply With Quote
Old 02-21-2004, 09:11 PM   #9
Vince M
Vince M's Avatar
3/8" bolts will drop right in but I drilled mine out to 7/16" and used fine thread bolts. They are not very common but I figured you might as well put the biggest bolt you can get in for the extra strength.
68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements.
Vince M is offline   Reply With Quote
Old 02-21-2004, 09:18 PM   #10
tomsC10R
tomsC10R's Avatar
Thanks for the suggestions everyone. I didn't get around to trying it today. So the fun will have to wait until tomorrow.
Jaycom,
Good question. So what size hardware have you guys replaced your rivets with?
Thanks everyone.
Tom
Old 02-21-2004, 10:20 PM   #11
JimKshortstep4x4
Talking
I use grade (5) 3/8-16 bolts to replace the rivets.
Jim
Old 02-21-2004, 10:24 PM   #12
mocwon
Keep On Truckin'
mocwon's Avatar
Air hammer with "sharp" chisel works best and is by far the easiest method. You will need to keep sharpening the chisel. Get a pointed chisel too so you can drive the rivets out after cutting the heads off. The rivets are fairly soft and cut easily with a sharp chisel and a good quality air hammer. I chiseled off all the rivets off one frame to get the entire rear leaf set up off and all the rivets off a frame to get the trailing bar set up removed so they could be switched. It went real smooth. Oh yeah, wear hearing protecting, gloves and eye protection. I use grade 8 bolts but grade 5 works fine too. 3/8" diameter is adequate. The grade 8 and grade 5 fasteners are both harder than the stock rivets. Do not use any bolts without proper grade 5 or 8 head markings. Without the head markings the bolts are typically a grade 2 and very weak which is an invitation to disaster. The real key is locking the nuts in place so they don't back off. To do this use lockwashers or self locking nuts; even Permatex thread locker is a good idea.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 02-22-2004, 12:44 AM   #13
OLDCHEV4X4
OLDCHEV4X4's Avatar
I removed my rivets with the drill method like mentioned earler. But i drilled my holes out to 11mm witch measures .433 , and used gr8 hardware 7/16-20 which measures .431 so i could get the tightest tolerance like a real rivet. I also used flat washers on either side and red thread locker. Torqued them down to about 35-40 ft.lbs. and never had one squeek or come loose.
Have fun!!
I removed over 60 rivets when i sandblasted my frame.
Randy
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 03-22-2004, 03:33 AM   #14
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
a suggestion.....bolt head up maybe????
however...im sure if a bolt does come out, its gonna snap before the nut comes loose...just suggestion.
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
