Old 02-21-2004, 12:57 PM   #1
DanoDMano
Pronounced "Pew-al-up"
DanoDMano's Avatar
truck wont idle, carb leaking fuel
My truck wont idle on its own, and the carburator is leaking fuel out the back thru the tube in my drawing. It sounds like the truck is missing.
I had this happen once before, but I figured I just flooded it, and in the morning it fired right up. This time it didnt work.
I have a newer Holley 600CFM, w/ electric choke....
Please excuse the crude drawing.
HELP!!!:p
Classic GM Trucks of Washington Club Member
1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's,
Power Locks,
Truck Photos
DanoDMano is offline   Reply With Quote
Old 02-21-2004, 01:10 PM   #2
Chevy67Tk
Chevy67Tk's Avatar
Possible Float valve is leaking or stuck open.
Chevy67Tk is offline   Reply With Quote
Old 02-21-2004, 01:17 PM   #3
DanoDMano
DanoDMano's Avatar
Where is that located?? Is it easy to remove and inspect?
Thanks.Holley Drawing Link
Power Locks,
Truck Photos
Old 02-21-2004, 01:28 PM   #4
gr8scott51
gr8scott51's Avatar
The floats sometimes develop a leak, allowing gas to get inside the float so it doesn't float. When the float doesn't float, it allows the fuel to continue entering the carb bowl. Got it? If it's like most carbs, you have to pull the top off the carb to access the float. You'll want to replace the gasket when you're done. A rebuild kit normally includes everything you'll need. Jewels pulled her 2 barrel off ot rebuild it, I've done a couple on the engine (if the carb to intake gasket doesn't need to be replaced).
good luck, scott
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 02-21-2004, 01:30 PM   #5
DanoDMano
DanoDMano's Avatar
Its not leaking out of the carb bowl. Its coming out of the tube at the rear of the carburator???
Power Locks,
Truck Photos
Old 02-21-2004, 01:35 PM   #6
Zeke
Active Member
Secondary float needle and seat are dirty or float sticking. Mine would flood out when I stopped and got progressively worse. Take the bowl off clean the needle and seat and get a good fuel filter. Mine had fine rust on it.
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
Old 02-21-2004, 01:38 PM   #7
gr8scott51
gr8scott51's Avatar
I think that tube is the bowl vent, made just for this reason.
good luck, scott
Old 02-21-2004, 01:45 PM   #8
DanoDMano
DanoDMano's Avatar
Thanks alot Guy's!! Man I'll never get over how cool this board has been. That sounds exactly like the problem with my truck.
I am going to tear into it this morning.
Power Locks,
Truck Photos
Old 02-21-2004, 01:49 PM   #9
gr8scott51
gr8scott51's Avatar
If I hadn't already promised to hepl rebuild my daughter's boyfriend's brakes, I'd come help.
good luck, scott
Old 02-21-2004, 02:41 PM   #10
DanoDMano
DanoDMano's Avatar
Thanks Scott!! Its always a learning experience with my truck, but I sure enjoy working on it!!
Thanks for all the help!!!
Power Locks,
Truck Photos
Old 02-21-2004, 02:55 PM   #11
jose
jose's Avatar
DanoDMano you might want to check the spark plugs also . To much fuel going down the intake will foul them . You might also check out the oil dip stick and see if there is a smell of gas if there is you will have to change your oil . Jose
68 GMC 4x4 SWB
jose6772@yahoo.com
jose is offline   Reply With Quote
Old 02-21-2004, 03:38 PM   #12
chevymaz
What are you looking at?
chevymaz's Avatar
mine was doing the same thing. I changed the Power valve and it took care of the problem. I have heard Holley's are notorious for blowing these
Greg
1971 GMC LWB
2005 Honda Element
2007 Honda Fit
chevymaz is offline   Reply With Quote
Old 02-21-2004, 03:57 PM   #13
68 Suburban
68 Suburban's Avatar
Greg
I know some people swear by them, but it seems like all I ever did was swear at them. Every Holley I ever had, developed a flooding problem at one time or another. I have not used a holley in 15 years.
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 02-21-2004, 08:14 PM   #14
DanoDMano
DanoDMano's Avatar
Yup, it was the secondary float!!! I disassembled it and cleaned it up. Works fine now!!!
I found a real cool website in the process too!!
Hotrod Info
Thanks as usual!!
Power Locks,
Truck Photos
Old 02-23-2004, 04:08 PM   #15
gr8scott51
gr8scott51's Avatar
not so dumb
Hey Dano, we're so as dumb as we look!!
