Keepin an eye out
quick questions...
well its been months and im finally almost finished with the brake conversion.
Whats the best way to bleed the brakes? The masters primed but everything else is new and dry.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
Keepin an eye out
Where do the spring wraps go? High, low... where theyre at?
Keepin an eye out
And lastly can I use this chrome case on my old alt.? The only difference I can see are the ridges on the rear.
I started mine by gravity bleeding them first. I opened the standard bleeders and closed them once fluid started coming out.
Then I installed some Speed Bleeders, they are the bleeder screws that have the spring in them. You crack them open and fluid can go out but air can't come in. They are really nice. Anyway I bled them with the Speed Bleeders last. Work great now.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Unregistered User
![]() Join Date: Dec 2001
A Mityvac works well, also.
Mike
71 SWB Stepside SB400/TH350 |
Just Don't Stop!
![]() Join Date: Feb 2004
what is a Mityvac? Never heard of that...
1968 C10 build in process TT LSA/6L90e/9" |
Try spinnin 4 rear tars
the way I've always bled brakes is with one other person. Start at the farthest brake from the master cylinder (right rear) and work your way closer (RR, LR, RF, LF). Apply pressure to the brake pedal, and somebody else opens the bleeder screw. When the pedal gets close to the end of its stroke, close the bleeder screw, let off the pedal, then repeat till you get good brake fluid coming out of the bleeder.
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
I am a Referee of life.
I would also start with the right rear, but go ahead and run enough brake fluid thru to change all of it.Brake fluid will pick up condensation moisture and needs changing ocassionally.Might as well do it while you're bleeding the new fronts.
BTW if you can get your wife to help she can definitely pump the brakes for you.If she volunteers to open and close the bleeders I'll trade you mine straight across.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#9 | |
Keepin an eye out
Funny you are asking that question
I am finally at the stage with my latest project to do the brake bleeding tomorrow. Then maybe a run around the block or two. Wootdog
1969 Chevelle 1990 IROC Z Convertible 2002 Silverado LT |
