Will my frame be strong enough?
This kind of goes along with my question about removing rivets, but not really.
I'm going to post a bunch of pictures. What I'm going to be removing is a reinforcement piece of metal that starts about 6 inches ahead of the spring perch and runs to and is riveted inbetween the the first crossmember behind the rearend and the frame (also where the track bar mount is) I'm not sure if all our trucks have these or not. I was talking to Ed at MotherTruckers and it sounds like I probably have a 3/4 frame. Oh yeah, I've got extra bracing on my trailing arms also, so I probably do have a 3/4 frame. Ok, so here's my question... I'm planning on doing a c notch and boxing in the inside of the frame around the c notch. First I need to remove this extra reinforcement and all the metal inbetween it. If I remove this reinforcement plate and never get around to the c notch ( and the extra boxing of the frame) Will my frame still be strong enough? Please bare with me, I know these pictures are kind of scarey looking. So what do ya think?
Tom 1968 C10 LWB. 402 BB, Holley MPI, 700R4. 4wheel Hydroboost Disk Brakes. |
invisable frame ???
Drivers side ( Don't ask me what the hose is for, I didn't do it
Passenger side
Driver side
Track bar mount, Frame, Reinforcement plate, Crossmember. And yes, I have to reroute the brake line too ![]()
Passenger side
Frame, Reinforcement Plate, Crossmeber
id fix that before i did anything comprimizing the strength of the frame it looks like its factory but my 3/4 doesnt have that i know for sure -kyle
1986 c-10 swb 5/7 drop 20'' coys 1958 belair 2door |
![]() Join Date: Feb 2003
RUST
Once you get the reinforcing plates off by the big crossmember I think you'll find some deep pitting on the lower frame rail. That flaky layered stuff between the plate & frame, used to be plate & frame.
Thanks,
Any other opinions. I do plan on boxing it in after I get the c notch done. I'm just concerned wheter it'll be safe to drive until I get that done. I guess it depends how much of the frame is still frame huh? Thanks
You'll want to remove the reinforcing plate and get rid of the rust no mater what. I had a frame that looked like that and when I removed the plate and rust I found the frame was paper thin. You can always bolt the plate back on afterwards.
............................................................ 68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements. |
