looking for pictures of 295 tires all around
tire shop has a sale of 295/50/15's, woundering what they look like in the back and possible front.
thanks S-C |
Roadtrip!
![]() Join Date: Feb 2003
295x50x15 on 8"rim up front...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Roadtrip!
n-50x15 rear. A little wider and a little taller.
sweet truck, got a set of centerlines here baggin for wide rubber
Just Don't Stop!
![]() Join Date: Feb 2004
too much stuff - any rubbing in the front? Do you know what your backspacing is on the front?
1968 C10 build in process TT LSA/6L90e/9" |
295 50R 15
Here you go
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" ![]() |
2
Another
2
Sorry Here it is
Roadtrip!
Stock ride height with 8" rally wheels on all 4 corners. No idea on backspacing. Never had a problem with rubbing. I would like to see a little more height in front to fill the wheelwell more. (imo) Only problem i have is wide tire= more maint.
Just Don't Stop!
I hear you there, I'm going for 295/40ZR20's on all four corners with 20x8.5 rims... I was unsure about clearance but you just made my mind up! Thanks!
-Chris
![]() Join Date: Sep 2002
i have bf goodrich 50 series all the way around my truck on deep dish aluminums. i wish i had pictures. i definelty had alotta good looks off of that truck. people love the wide tires. i also put a 2 inch drop on it to bring it down just a little on the tires.
Chris |
i like the look of your truck 70'
#13 |
Roadtrip!
TTT for 71 rat. Hope this helps ya out!
#14 |
i love my 295s, they are so wide and bad looking in the front with 1 coil cut out.
Brandon, SD 69 GMC 1/2 ton 2wd wide long bed with wood 3 on the tree 350 engine 4 bolt main rv cam AIM = Alphray04 |
#15 |
ran out of money
Thanks too much stuff!!
Gotta love wide tires!!! Thanks again Rat
Modify everything, leave nothing alone!~ ![]() ![]() |
#16 |
go bucks!
THANKS FOR THE PICS GUYS!! i have 275 70r15's on all four corners on mine but i been wanting to go to another size to fill up the wheel-well better....this helped make up my mind!!
'68 swb 1/2t 350/350th '86 lngbd 3/4 TON parts getter '49 gmc 1/2 t 5 window 350/350th '96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know? |
