3/4 ton 4x4 hub part needed.
Anyone got this part circled in red... its the inner most gear that is attached onto the axle. Rod
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
lockout gear
I don't have one but I think it's the same on a 1/2 ton.It looks like the same gear that came with a set I got on ebay.They were from a 78 1/2 ton got both sides for about $20. I have a friend who has lots of spicer stuff I'll ask him if you want.
68 K-10,79 K-10,80 C-30 57 chevy convertible 79 Z28 |
Yah sure ask him.... and I'll look up that part in my parts book and see what else it fits also.
Hi
My friend didn't have anything now but I did see a set on ebay for a F@#d they look the same except a red center listed under locking hubs pretty pricey though $130!
I actually tried a f*%d piece and it wouldn't work.... it would have worked if I used more pieces from the blue oval. The hubs I belive would interchage if you used complete ones. Easy enough to swap the plastic dial. But it just wasn't meant to be for me in this case.
The was a diameter problem if I remember about it fitting into the bigger housing piece. Didnt find it on ebay anyway.
ebay item #2461032892 listed under ford truck dana 44 locking hubs.Good luck!
